I’m looking for a solution to connect Jetson to a relay in the following link:
It requires 3 outputs from Jetson Nano:
1. DC+ = +5V constant high voltage rail value
2. DC- = ground rail
3. VSig = Signal Voltage that can provide either +5V or ground depending on the appropriate computed signal. This voltage has to provide at least 10mA current to enable it to trigger a dc voltage relay switch module.
I know the GPIO can provide enough Voltage but not Amp.
Is there any solution that the board provide?
Best regards.
