New to the libargus library, I want to know the following questions:
- How to get bayer raw data using libargus api and save it as a file(I want to save both raw data and data processed by the ISP)
- When the ISP in libargus controls the exposure and gain, can third-party programs obtain the data controlled by the ISP in real time through API
- Can jetson tx2’s ISP select the data stream of the user’s own application as the input data?
Does anyone understand libargus? Can you help me, thanks
I can list 4 videos by executing ls /dev/video*. Why can only one device be seen using argus_camera?
dev@dev-desktop:~/share/nvcapture_test$ ls /dev/video*
/dev/video0 /dev/video1 /dev/video2 /dev/video3
execute argus_camera -i
dev@dev-desktop:~/share/nvcapture_test$ argus_camera -i
Executing Argus Sample Application (argus_camera)
Argus Version: 0.98.3 (multi-process)
Argus extensions:
BayerSharpnessMap: supported
DebugCaptureSession: supported
DeFog: supported
FaceDetect: not supported
InternalFrameCount: supported
SensorPrivateMetadata: supported
Number of camera devices: 1
Device: 0
Max AE Regions: 64
Max AWB Regions: 64
Focus Position Range: 0 - 0
Aperture Position Range: 0 - 0
Aperture Motor Speed Range: 1 - 1
Lens Aperture Available values: 2.4,
Isp Digital Gain Range: 1 - 256
Number of sensor modes: 6
Sensor mode: 0
Resolution: 1920x1296
Exposure time range: 34000 - 550385000 ns
Frame duration range: 33333334 - 550486208 ns
Framerate range: 1.81658 - 30 fps
InputBitDepth: 12
OutputBitDepth: 12
Analog gain range: 1 - 15.5
SensorModeType: SENSOR_MODE_TYPE_BAYER
Sensor mode: 1
Resolution: 1920x1286
InputBitDepth: 12
OutputBitDepth: 12
Sensor mode: 2
Resolution: 1920x1086
Frame duration range: 40000000 - 550486208 ns
Framerate range: 1.81658 - 25 fps
InputBitDepth: 10
OutputBitDepth: 10
Sensor mode: 3
InputBitDepth: 10
OutputBitDepth: 10
Sensor mode: 4
Frame duration range: 16666667 - 550486208 ns
Framerate range: 1.81658 - 60 fps
InputBitDepth: 12
OutputBitDepth: 12
Sensor mode: 5
InputBitDepth: 12
OutputBitDepth: 12
Don’t understand your question.
system
closed
#9
