**• Hardware Platform (Jetson / GPU)**Jetson
• DeepStream Version5.1
• TensorRT Version
In test1 of python api.
I tried to use my pretrained Yolov5 model on deepstream. When I tried to get some results inferred by the model in deepstream, the results seemed wrong. I just modified the function osd_sink_pad_buffer_probe in test1 and changed the model to yolov5. I tried to get information from NvDsObjectMeta.detector_bbox_info but it said there was no attribute called this. Then I turned to rect_params, but this gave me wrong datas, which were too big. (btw, input video was created with 1024×1024 images)
Also, I’ve tried to add_probe to the pgie’s sink. This gave me even none data. I’m not sure but I guess it’s the video-convertor’s cause. However, where should I get the true results inferred by my model from? Of course, the confidence was also very big with an average of more than 200.
Here is my sink_pad_buffer_probe
def pgie_sink_pad_buffer_probe(self,pad,info,u_data):
frame_number=0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.glist_get_nvds_frame_meta()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
except StopIteration:
break
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
res={'time':frame_number,'numofobjects':num_rects,'objects':[]}
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.glist_get_nvds_object_meta(l_obj.data)
break
#obj_counter[obj_meta.class_id] += 1
bbox={'xmin':obj_meta.rect_params.left,'xmax':obj_meta.rect_params.left+obj_meta.rect_params.width,'ymin':obj_meta.rect_params.top+obj_meta.rect_params.height,'ymax':obj_meta.rect_params.top}
res['objects'].append({'label':obj_meta.obj_label[obj_meta.class_id],'confidence':obj_meta.confidence,'bbox':bbox.copy()})
#END
try:
l_obj=l_obj.next
break
self.resq.put(json.dumps(res))
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
And I tried to add_probe to pgie,nvosd…
osdsinkpad = pgie.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of pgie \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER,
self.pgie_sink_pad_buffer_probe, 0)
So, what should I do to get my bboxes and confidence?
