How to get clang?
I just got a Jetson TK1 board and I need to use clang. Unfortunately with the default Ubuntu install I cannot get clang at all, it is not part of the available packages.
Is there a source that I’m missing to get clang?
Thanks in advance,
Manu
I’m not near a Jetson to look at right now, but the default repository list is mostly commented out in /etc/apt/sources.list. I suspect that if you added some of the optional repos then clang would show up under apt search.
I just verified that if other repositories are enabled, then clang is available on Jetson.
Here’s my repo list:
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ trusty main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-updates main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ports.ubuntu.com/ubuntu-ports/ trusty universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty universe
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-updates universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-updates universe
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty-backports main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-backports main restricted
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-security main restricted
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-security universe
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-security multiverse
