• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0
• TensorRT Version 7
• NVIDIA GPU Driver Version (valid for GPU only) 440
• Issue Type( questions, new requirements, bugs) question
I’m able to get classifier raw tensor metadata from the sgie_pad_buffer_probe
in deepstream-infer-tensor-meta-test
app, but how to do so in deepstream-app
itself?
Right now, if I use the same code in all_bbox_generated
function, it’s not entering the third loop (probably because the data is NULL there). This function is probably called in gie_processing_done_buf_prob
which should contain all metadata (pgie+sgie).
static void
all_bbox_generated (AppCtx * appCtx, GstBuffer * buf,
NvDsBatchMeta * batch_meta, guint index)
/* Iterate each frame metadata in batch */
for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) l_frame->data;
/* Iterate object metadata in frame */
for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
NvDsObjectMeta *obj_meta = (NvDsObjectMeta *) l_obj->data;
/* Iterate user metadata in object to search SGIE's tensor data */
for (NvDsMetaList * l_user = obj_meta->obj_user_meta_list; l_user != NULL;
l_user = l_user->next) {
std::cout << "kk";
