I want to get CPU id in tx2 to make a license? how can I get it ?
when I use asm, it will occur “impossible constraint in ‘asm’”
ClancyLian,
Could you elaborate the definition of “id” here?
the id is series number which is different between two machine and can’t be changed by user.
Are you talking about the serial number of the processor?
yes!
when I use
dmidecode -t 4
to inquire CPU info, the system will restart. What’s the problem with it ?
when I use lshw, i can get serial: 0324517130259, if this serial is unique, and how can I get it in program ?
nvidia@tegra-ubuntu:~$ lshw
WARNING: you should run this program as super-user.
tegra-ubuntu
description: Computer
product: quill
<b>serial: 0324517130259</b>
width: 64 bits
capabilities: cp15_barrier setend swp
*-core
description: Motherboard
physical id: 0
capabilities: nvidia_quill nvidia_tegra186
*-cpu:0
description: CPU
product: a57_cluster_power_states
physical id: 0
bus info: cpu@0
capacity: 2035MHz
capabilities: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpufreq
*-cpu:1
description: CPU
product: a57_core_power_states
physical id: 1
bus info: cpu@1
capacity: 2035MHz
*-cpu:2
description: CPU
product: a57_crossover_thresholds
physical id: 2
bus info: cpu@2
capacity: 2035MHz
*-cpu:3
description: CPU
product: cpu
physical id: 3
bus info: cpu@3
capacity: 2035MHz
*-cpu:4
description: CPU
product: cpu
physical id: 4
bus info: cpu@4
capacity: 2035MHz
*-cpu:5
description: CPU
product: cpu
physical id: 5
bus info: cpu@5
capacity: 2035MHz
*-cpu:6 DISABLED
description: CPU
product: cpu
physical id: 6
bus info: cpu@6
*-cpu:7 DISABLED
description: CPU
product: cpu
physical id: 7
bus info: cpu@7
*-cpu:8 DISABLED
description: CPU
product: cpu
physical id: 8
bus info: cpu@8
*-cpu:9 DISABLED
description: CPU
product: denver_cluster_power_states
physical id: 9
bus info: cpu@9
*-cpu:10 DISABLED
description: CPU
product: denver_core_power_states
physical id: a
bus info: cpu@10
*-cpu:11 DISABLED
description: CPU
product: denver_crossover_thresholds
physical id: b
bus info: cpu@11
*-cpu:12 DISABLED
description: CPU
product: l2-cache0
physical id: c
bus info: cpu@12
*-cpu:13 DISABLED
description: CPU
product: l2-cache1
physical id: d
bus info: cpu@13
*-memory
description: System memory
physical id: e
*-network:0
description: Ethernet interface
physical id: 1
logical name: usb0
serial: 6a:a5:b5:0a:95:3c
capabilities: ethernet physical
configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=tegra-xudc link=no multicast=yes
*-network:1 DISABLED
physical id: 2
logical name: dummy0
serial: 0a:9d:f4:74:1d:b0
configuration: broadcast=yes driver=dummy driverversion=1.0
*-network:2
physical id: 3
logical name: wlan0
serial: 00:04:4b:8d:93:78
configuration: broadcast=yes driver=wl driverversion=0 multicast=yes
*-network:3
physical id: 4
logical name: usb1
serial: 5a:c0:ce:43:cf:28
*-network:4
physical id: 5
logical name: eth0
serial: 00:04:4b:8d:93:7a
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=eqos duplex=full ip=192.168.1.235 link=yes multicast=yes port=MII speed=100Mbit/s
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Yes, that is unique but it is not the serial for “CPU” but the tegra.
dmidecode is an intel-only tool, it does not work correctly on the ARM architecture.
I think it’s a bug that it’s still built on Ubuntu for ARM.
See this thread: https://devtalk.nvidia.com/default/topic/1027966/jetson-tx2/how-to-read-tx2-modules-serial-number-in-code-/
You can parse it from /proc/cmdline
