• Jetson Orin Nx 16GB • 7.0 • JP6.0 • 8.6.2.3 • NVIDIA GPU Driver Version (valid for GPU only) • questions
I followed the instructions in this document to configure AI NVR, and everything went smoothly.
My question is, how can I retrieve the inference results from DeepStream?
I checked the logs of the DeepStream container, and it seems to be working normally.
Thank you very much for your reply.
I want to use VLC to open the RTSP video stream inferred by DeepStream.
If feasible, my next step will be to simultaneously display the raw data from the IP cameras and the inference results from DeepStream on a video wall of VST.
