How to get drive os 6.0.9?
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I tried to use docker to install the system for orin. The main steps are as follows:
1 sudo docker run -it --privileged --net=host -v /dev/bus/usb:/dev/bus/usb -v /mnt/data2/nvidia:/home/nvidia/ nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
2 sudo docker run -it --privileged --net=host -v /dev/bus/usb:/dev/bus/usb -v /drive_flashing:/drive_flashing nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
3 ./flash.py /dev/ttyACM1 p3710
But I found that after installing the system, the version is 6.0.8.1, but we want to install 6.0.9, then how to get this version of the system?
Dear @deng.shigang,
DRIVE OS 6.0.9 is not available in DevZone. As mentioned in another thread can you reach out to your NVIDIA representative or discuss internally with your team about NVONLINE access.
