I’m working on a computer vision project where we’re trying to have a view of the live camera feed as well as the output from deepstream on the same screen, but in two different windows.
When we run sudo deepstream-app -c deepstream_app_config.txt we get the following error:
Your camera parameters set improperly.
use below to check your camera parameters:
$ sudo apt-get install v4l-utils
$ v4l2-ctl -d /dev/video0 --list-formats-ext
What do you mean have two streams from the same camera?
Hi, I’m working with @kareddy084 on this project. Thank you for your response.
Running two pipelines as you suggest, can we use the same USB camera as the source in both pipelines?
At the moment we are running a window with the same video feed (as seen in the screenshot above as Boson_320 : RAW16 Linear). Then when we launch the deepstream app with the same video source specified we get the error: ERROR from src_elem: Device ‘/dev/vidoe0’ is busy. When the first video feed is not running, the deepstream app does run correctly, so the paramaters etc are correct.
We want one window with just the live video feed, and a second window that runs inference and is manipulated using Deepstream. Any advice on how to achieve this will be greatly appreciated.
Sorry, deepstream-app -c config -c config should not work for same usb camera source.
can you try add tee after nvv4l2decoder, like
tee name=t !
t. ! queue ! nvvideoconvert ! nvegltransform ! nveglglessink
t. ! queue ! nvstreammux …! nvinfer … ! … ! nveglglessink
