How can we get multiple video output streams from the Orin module such as HDMI?
It seems PCIe is the only way to get video out. Can we just plug a graphics card into Orin PCIe lanes?
Please share your use-case. How many video outputs are required? And is it fine to output to DP port or HDMI out is a hard requirement? On Orin developer kit we only support DP out.
We would like to have up to six video outputs. HDMI is preferred but DP could also work.
I found this in the NVIDIA Jetson AGX Orin Series Technical Brief v1.1:
The Display Port can support 2 displays using the Multi-stream mode on DP1.4
So we could have two displays using DP MST but would like to have more than two.
MST will be supported after JP5.0 GA.
