• Hardware Platform (GPU)
• DeepStream Version 6.2
• Issue Type(new requirements)
I have a program to dynamic add and delete sources, https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/runtime_source_add_delete
now I want to get one source from streammux , and drop the other sources, the source I want can dynamic use index or other flag to get , maybe I want first source , maybe third source source. How to do it? should I use nvstreamdemux , or without it I can drop the frames from other sources which i don’t want.
yuweiw
August 21, 2023, 10:37am
3
Yes. You need to use nvstreamdemux. You can refer to the source code: sources\apps\sample_apps\deepstream-ucx-test3\client\deepstream_ucx_test3_app_client.c.
g_snprintf (pad_name, 15, "src_%u", 0);
demuxsrcpad = gst_element_get_request_pad (streamdemux, pad_name);
I have tried it , when I set
It can display the first source, but when I set
g_snprintf (pad_name, 15, "src_%u", 1);
it can’t display the second source, with black screen.
yuweiw
August 22, 2023, 2:39am
5
Could you try the command below in your env?
1.save both source_0 and source_1
gst-launch-1.0 -e nvstreammux name=mux batch-size=2 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt batch-size=2 ! nvstreamdemux name=demux filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! queue ! mux.sink_0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! queue ! mux.sink_1 demux.src_0 ! "video/x-raw(memory:NVMM), format=NV12" ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=RGBA" ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=./out_0.mp4 demux.src_1 ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=RGBA" ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=./out_1.mp4
2.save source_1
gst-launch-1.0 -e nvstreammux name=mux batch-size=2 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt batch-size=2 ! nvstreamdemux name=demux filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! queue ! mux.sink_0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! queue ! mux.sink_1 demux.src_1 ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=RGBA" ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=./out_1.mp4
Hi, I have write a demo, it can display at first by removing tiler element,
but sometime the demo can not change the source to show.
multi-gpu-test-ds63.zip (14.9 KB)
yuweiw
August 28, 2023, 5:40am
7
1.Are the sources added to the pipeline sometimes livesources or mp4 files?
2.If you use nvstreamdemux, there is no need to use nvmultistreamtiler in your code.
yuweiw
August 29, 2023, 11:12am
9
1.If it’s live source, you can set the live-source parameter to nvstreammux.
Can the pipeline I attached before select the stream normally in your environment?
Yes, I have try the pipeline you attached, it can run.
And I also set the live-source parameter in the code , you can see the code I attached
yuweiw
August 31, 2023, 8:23am
11
Could you try to use the fixed number of sources first?
system
Closed
September 19, 2023, 12:55am
12
