hi,
目前我们有Orin 64G模组其中有两个生产批次,由于PCN2010100导致FAB由500变更为501,
那有更好的办法从ubuntu系统里面直接读取获取FAB值吗?或者有没有更好的方法在orin系统运行时区分是否是新批次模组?
之前都是通过flash.sh看日志输出,但是这个方法并不方便。
sudo i2cdump -y 0 0x50
我是建議直接升級BSP比起用這種方法實際…
升级BSP? 现在已经使用JetPack5.1.3了
那你要把module做區分的目的是?
主要是massflash刷机包的生成方法使用不同FAB数值,这也意味着新旧批次的模组用生成两个massflash package
FAB 500跟501在35.5應該是可以用同一包mfi package的
那都用FAB500还是FAB501?
hi,
在JetPack5.1.3中,我用了massflash package为FAB500在新批次模组(FAB501)上烧录,结果发现烧录失败,失败日志如下
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Serial Number: 1422024345338
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 76
max_index=75
writing item=59, 1:3:primary_gpt, 512, 19968, gpt_primary_1_3.bin, 16896, fixed-<reserved>-0, 1ef8334aa7936d5327920f5cab6231c79829e8cb
Writing primary_gpt partition with gpt_primary_1_3.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/internal/gpt_primary_1_3.bin of=/dev/mmcblk0 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0185727 s, 910 kB/s
Writing primary_gpt partition done
Error: Invalid argument during seek for read on /dev/mmcblk0
[ 28]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
- the xml indicates the gpt is larger than the device storage
- the xml might be invalid
- the device might have a problem.
Please make correction.
Flash failure
Cleaning up...
后来发现p3701.conf.common文件中有对新批次FAB501的修改
update_local_cfgfile()
# Update "num_sectors" in local cfgfile for the device
# with FAB=501 and BOARDSKU=0004/0005
local local_cfgfile="${1}"
if [ "${board_FAB}" == "501" ] && [[ "${board_sku}" == "0004" || "${board_sku}" == "0005" ]]; then
sed -i 's/num_sectors=\"124321792\"/num_sectors=\"124190720\"/' "${local_cfgfile}"
fi
然后使用FAB501的massflash package就可以成功对新批次FAB501进行烧录了。
我尝试使用FAB501的massflash package对模组为FAB500进行烧录
发现massflash烧录日志中出现如下信息,但是这个error不会导致刷机失败。
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/mmcblk0 appears to be used, you can fix the GPT to use all of the space (an extra 131072 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_1_3.bin
dd if=/mnt/internal/gpt_secondary_1_3.bin of=/dev/mmcblk0 bs=1 skip=0 seek=63585631744 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0303894 s, 556 kB/s
Writing secondary_gpt partition done
Fix/Ignore? Fix
Model: MMC G1M15M (sd/mmc)
Disk /dev/mmcblk0: 63.7GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
2 20.5kB 134MB 134MB A_kernel msftdata
3 134MB 135MB 786kB A_kernel-dtb msftdata
4 135MB 168MB 33.2MB A_reserved_on_user msftdata
5 168MB 302MB 134MB B_kernel msftdata
6 302MB 303MB 786kB B_kernel-dtb msftdata
7 303MB 336MB 33.2MB B_reserved_on_user msftdata
8 336MB 420MB 83.9MB recovery msftdata
9 420MB 421MB 524kB recovery-dtb msftdata
10 421MB 488MB 67.1MB fat32 esp boot, esp
11 488MB 572MB 83.9MB recovery_alt msftdata
12 572MB 572MB 524kB recovery-dtb_alt msftdata
13 572MB 639MB 67.1MB esp_alt msftdata
14 639MB 1059MB 419MB UDA msftdata
15 1059MB 1562MB 503MB reserved msftdata
1 1562MB 63.6GB 62.0GB ext4 APP msftdata
完整日志如下
flash_3-2.3_0_20240808-155923.log (42.8 KB)
FAB501和FAB500模组的差异主要就在sectors大小上面,所以我也不清楚能否可以直接同用一个mfi package,希望您可以给个答复,谢谢!
請你直接把那段檢查拿掉之後重新建mfi package.
總之就是讓不論FAB=500 或是501都要執行 sed -i ‘s/num_sectors="124321792"/num_sectors="124190720"/’ “${local_cfgfile}”
這個執行完之後用同一包就能燒錄了
好的,也就是FAB500或者FAB501的模组都可以用num_sectors="124190720"这个分区大小就可以哈?
這一段加入的原因是因為FAB501使用的emmc density沒有FAB 500的大所造成
所以如果統一都用小一點的size的話就可以通用
好的,在请教一个问题,除了这个emmc density的差异之外
FAB501这个参数,在做包的时候相对比与FAB500,还有其他差异吗?
理論上是沒有
您看一下我这个日志,我在FAB500的模组上用小一点的size(FAB501 mfi pakage),会有这样的情况
