Hi all, I am trying out ParaView Connector 100.0.1 and UE5 Connector version 105.1.237, and I’m also new to using USD. My goal is to get a ParaView visualization with timesteps into Unreal. I find that Omniverse Create can play the sequence, but when opening OV Nucleus USD scene in Unreal as a new level, importing a USD as a Blueprint, or importing OV Nucleus USD into an existing level, I find that there are keyframes for each timestep in the LevelSequencer / ActorSequencerComponent, but there is no difference between each keyframe; no animation occurs.
In other words, it seems like the clips defined in the USDs, which load different meshes at each timestep I think, are not getting translated into a proper sequence in Unreal.
Is this expected? Are there any workarounds? I was very hopeful it would “just work.” Thanks in advance for any help.
