How to get result_label from custom classification parser
GeForce RTX 2080 Ti 2
Deepstream 4.0
TensorRT 6.0.1
Driver Version: 440.64.00
I have a cascade of neural networks. Detection and two parallel classifiers. One classifier works with the standard post-processing function, and the second - text recognition (the output in my case is a batch, 1, 1, 8x36). To process this output, I upgraded the post processing function for the network:
extern "C" bool NvDsInferParsetextRecognize(
        std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
        NvDsInferNetworkInfo  const &networkInfo,
        float classifierThreshold,
        std::vector<NvDsInferAttribute> &attrList,
        std::string &attrString)
    unsigned int numAttributes = outputLayersInfo.size();
    static const std::string labels = "0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ";
    for (unsigned int l = 0; l < numAttributes; l++)
        NvDsInferDimsCHW dims;
        getDimsCHWFromDims(dims, outputLayersInfo[l].dims);
        unsigned int numClasses = 36;
        float *outputCoverageBuffer =
            (float *)outputLayersInfo[l].buffer;
        bool attrFound = false;
        NvDsInferAttribute attr;
        std::string text;
        for (unsigned int k = 0; k<8; k++)
            float maxProbability = -254;
            unsigned int index;
            for (unsigned int c = k*numClasses; c < (k+1)*numClasses; c++)
                float probability = outputCoverageBuffer[c];
                if (probability > maxProbability)
                    maxProbability = probability;
                    attrFound = true;
                    attr.attributeIndex = l;
                    attr.attributeValue = 0;
                    attr.attributeConfidence = 1.0;
                    index = c-(k*numClasses);
            text.append(1,labels.at(index));
        if (attrFound)
            attr.attributeLabel = text.c_str();
            attrList.push_back(attr);
            if (attr.attributeLabel)
                attrString.append(attr.attributeLabel).append(" ");
    return true;
I see result_label on the video after processing after the second classifier, but I can’t print it in the console:
gchar text[128] = "";
snprintf(text, 128, "%s", label->result_label);
if (triger) {
    g_print("class:%s\n", label->result_label);
    printf("text: %s\n",  text);
with result:
class:
text:
I’m not sure this is not a deepstream problem. Can someone advise something how to solve my problem.
Suppose the label should be accessed like this:
NvDsLabelInfo *label = (NvDsLabelInfo *) l_label->data;
if (label->result_label[0] != '\0') {
    sprintf (str_ins_pos, " %s", label->result_label);
If you still cannot get the correct output, please share your source with us.
I changed the code according to your recommendations and in the console I get:
CA8450BP
[Invalid UTF-8] class:\x10\xaf\xbe\xdea\x7f
text: ���a
First row - printf("%s\n", text.c_str()) from parser function NvDsInferParsetextRecognize
second row - g_print(“class:%s\n”, label->result_label); from tiler_src_pad_buffer_probe
third row - printf(“text: %s\n”, text); from tiler_src_pad_buffer_probe
This is related to the character used in your label file.
Is your label file supported by the UTF-8 format?
Do you have any character that not be included in the UTF-8?
I do not use a labels file for a network. All labels are listed as characters in this variable inside the post-processing function from the first message:
Would you mind to share the change you have made so we can check it further?
custom_parser.cpp:
#include <cstring>
#include <iostream>
#include "nvdsinfer_custom_impl.h"
/* This is a sample classifier output parsing function from softmax layers for
 * the vehicle type classifier model provided with the SDK. */
/* C-linkage to prevent name-mangling */
        std::string &attrString);
    //static const std::string labels = "0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ";
        std::string text;
            unsigned int index;
                    attrFound = true;
        printf("%s\n", text.c_str());
        if (attrFound)
    return true;
/* Check that the custom function has been defined correctly */
CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE(NvDsInferParsetextRecognize);
from deepstream_test3_app.cpp:
static GstPadProbeReturn
tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data){
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        guint batch_id = frame_meta->batch_id;
        int  surface_id = frame_meta->source_id;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
            guint class_id = 2555;
            gfloat model_prob = 0;
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            guint64 track_id = obj_meta->object_id;
            NvOSD_RectParams rect = obj_meta->rect_params;
            gint color_id = obj_meta->class_id;
            gfloat color_prob = obj_meta->confidence;
            for (NvDsMetaList * l_class = obj_meta->classifier_meta_list; l_class != NULL; l_class = l_class->next) {
                NvDsClassifierMeta *cmeta = (NvDsClassifierMeta *) l_class->data;
                for (NvDsMetaList * l_label = cmeta->label_info_list; l_label != NULL; l_label = l_label->next) {
                    class_id = label->result_class_id;
                    model_prob = label->result_prob;
                    if (color_id==12 && label->result_label[0] != '\0' ){
                        sprintf(text, "text: %s", label->result_label);
    frame_number++;
    return GST_PAD_PROBE_OK;
I understood my mistake.
I apologize for the stupidity, but I can’t understand how to save class numbers from multi label classifications in NvDsLabelInfo
Please check if this sample helps:
/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/deepstream_infer_tensor_meta_test.cpp
NvDsLabelInfo *label_info =
    nvds_acquire_label_info_meta_from_pool (batch_meta);
label_info->result_class_id = attr.attributeValue;
label_info->result_prob = attr.attributeConfidence;
Super
