How to get text console on DSI display?
I have the following problem: the graphical environment works just fine on a TFT screen connected to the DSI interface. However, when I press CTRL-alt F4 to get into a text console, the screen goes blank. dmesg output also shows that the screen is blanked / disabled (I tried resolutions from 800x600 to 1920x1080 but no difference). Fbset shows the right resolution. When I configure the system to use HDMI only, I get the console on the HDMI screen (TFT panel is fb0 so it will take precedence over the HMDI screen).
Somehow the virtual console won’t show on the TFT display and I don’t see why not. I hope somebody can point me in the right direction on where to look.
Please share dmesg with ctrl+alt +f4.
Here it is:
[ 8.783086] apex 0000:01:00.0: Apex performance not throttled due to temperature
[ 8.956539] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 8.957209] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.923321] fuse init (API version 7.26)
[ 13.130278] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.130295] Bluetooth: BNEP socket layer initialized
[ 13.570729] tegradc 15200000.nvdisplay: unblank
[ 61.362844] tegradc 15200000.nvdisplay: blank - powerdown idx: 0
[ 61.416428] tegradc 15200000.nvdisplay: blank - powerdown idx: 0
Full dmesg please and also the syslog.
Here is the full dmesg. I don’t have the syslog available right now; will post that later
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.9.140+ (root@roadrunner2) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #57 SMP PREEMPT Mon Mar 29 20:12:55 CEST 2021
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[    0.000000] OF: fdt: - 80000000 ,  70000000
[    0.000000] OF: fdt: - f0200000 ,  179e00000
[    0.000000] OF: fdt: - 26a600000 ,  200000
[    0.000000] OF: fdt: - 26ae00000 ,  200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Found vpr, start=0x26c600000 size=ba00000
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] On node 0 totalpages: 2007552
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 523776 pages, LIFO batch:31
[    0.000000]   Normal zone: 23232 pages used for memmap
[    0.000000]   Normal zone: 1483776 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc1eae1c000 s61592 r8192 d32616 u102400
[    0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1976128
[    0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware console=tty1 console=tty2 fbcon=map:1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x26bce0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr=0xba00000@0x26c600000 bl_prof_dataptr=0x10000@0x26a040000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29164(89%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7779108K/8030208K available (15294K kernel code, 2936K rwdata, 6680K rodata, 8640K init, 655K bss, 185564K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e70000   (  8640 KB)
[    0.000000]       .data : 0xffffff8009e70000 - 0xffffff800a14e008   (  2937 KB)
[    0.000000]        .bss : 0xffffff800a14e008 - 0xffffff800a1f1e3c   (   656 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf07ac0000   (   122 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc1eb000000   (  7856 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.001137] Console: colour dummy device 80x25
[    0.001145] console [tty1] enabled
[    0.001151] kmemleak: Kernel memory leak detector disabled
[    0.001160] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.001168] pid_max: default: 32768 minimum: 301
[    0.001474] Security Framework initialized
[    0.001628] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.001633] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.002219] ftrace: allocating 47221 entries in 185 pages
[    0.126028] sched-energy: Sched-energy-costs installed from DT
[    0.126039] ASID allocator initialised with 65536 entries
[    0.161661] tegra-id: chipid=21817.
[    0.161667] tegra-id: opt_subrevision=1.
[    0.161684] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.161692] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/ruffled-live-tx2-8gb.dts
[    0.161698] DTB Build time: Dec  6 2021 21:14:44
[    0.209612] CPU1: Booted secondary processor [4e0f0030]
[    0.241243] CPU2: Booted secondary processor [4e0f0030]
[    0.273036] CPU3: Booted secondary processor [411fd073]
[    0.305018] CPU4: Booted secondary processor [411fd073]
[    0.337019] CPU5: Booted secondary processor [411fd073]
[    0.337075] Brought up 6 CPUs
[    0.337078] SMP: Total of 6 processors activated.
[    0.337084] CPU features: detected feature: 32-bit EL0 Support
[    0.337799] CPU: All CPU(s) started at EL2
[    0.337832] alternatives: patching kernel code
[    0.347335] devtmpfs: initialized
[    0.373986] Initilizing CustomIPI irq domain
[    0.374176] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.374186] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.375065] pinctrl core: initialized pinctrl subsystem
[    0.375255] OS set in device tree is not L4T.
[    0.375410] regulator-dummy: no parameters
[    0.375555] Initializing plugin-manager
[    0.375612] Plugin module not found
[    0.375648] Plugin-manager status disabled
[    0.376971] NET: Registered protocol family 16
[    0.377798] pstore: using zlib compression
[    0.377814] console [pstore-1] enabled
[    0.377817] pstore: Registered ramoops as persistent store backend
[    0.377821] ramoops: attached 0x200000@0x26a080000, ecc: 0/0
[    0.396616] cpuidle: using governor menu
[    0.397726] bpmp: waiting for handshake
[    0.397730] bpmp: handshake completed
[    0.397743] bpmp: synchronizing channels
[    0.397760] bpmp: channels synchronized
[    0.397763] bpmp: mail init ok
[    0.399454] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.399459] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.399463] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.399466] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.399469] arm-smmu 12000000.iommu: 	nested translation
[    0.399475] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.399480] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.399484] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.399488] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.399491] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.401427] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[    0.401439] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.404106] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.405228] Registering BPMP clocks...
[    0.405316] tegra_bpmp_clk_init: clock init ok (638 clks)
[    0.406919] tegra_powergate_init: DONE
[    0.406927] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/ruffled-live-tx2-8gb.dts
[    0.406933] DTB Build time: Dec  6 2021 21:14:44
[    0.408345] Tegra reboot handler registered.
[    0.409596] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.409871] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.409912] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.409918] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[    0.409923] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.410396] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.410417] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.411252] iommu: Adding device 3460000.sdhci to group 0
[    0.412927] iommu: Adding device 3400000.sdhci to group 1
[    0.415088] iommu: Adding device 3507000.ahci-sata to group 2
[    0.415114] arm-smmu: forcing sodev map for 3507000.ahci-sata
[    0.415815] iommu: Adding device 3160000.i2c to group 3
[    0.416421] iommu: Adding device c240000.i2c to group 4
[    0.416887] iommu: Adding device 3180000.i2c to group 5
[    0.417434] iommu: Adding device 3190000.i2c to group 6
[    0.418062] iommu: Adding device 31b0000.i2c to group 7
[    0.418516] iommu: Adding device 31c0000.i2c to group 8
[    0.418969] iommu: Adding device c250000.i2c to group 9
[    0.419441] iommu: Adding device 31e0000.i2c to group 10
[    0.422858] iommu: Adding device 3210000.spi to group 11
[    0.423291] iommu: Adding device c260000.spi to group 12
[    0.423765] iommu: Adding device 3240000.spi to group 13
[    0.424840] iommu: Adding device 3100000.serial to group 14
[    0.425407] iommu: Adding device 3110000.serial to group 15
[    0.425827] iommu: Adding device c280000.serial to group 16
[    0.426297] iommu: Adding device 3130000.serial to group 17
[    0.427946] iommu: Adding device 2490000.ether_qos to group 18
[    0.427969] arm-smmu: forcing sodev map for 2490000.ether_qos
[    0.428948] iommu: Adding device b000000.rtcpu to group 19
[    0.431433] iommu: Adding device 13e10000.host1x to group 20
[    0.431877] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[    0.432317] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[    0.432728] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[    0.433144] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[    0.433629] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[    0.434074] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[    0.434505] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[    0.434887] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[    0.435475] iommu: Adding device 150c0000.nvcsi to group 29
[    0.436238] iommu: Adding device 15700000.vi to group 30
[    0.436690] iommu: Adding device 15600000.isp to group 31
[    0.437320] iommu: Adding device 15200000.nvdisplay to group 32
[    0.438209] iommu: Adding device 15340000.vic to group 33
[    0.438512] iommu: Adding device 154c0000.nvenc to group 34
[    0.438808] iommu: Adding device 15480000.nvdec to group 35
[    0.439266] iommu: Adding device 15380000.nvjpg to group 36
[    0.439609] iommu: Adding device 15500000.tsec to group 37
[    0.439893] iommu: Adding device 15100000.tsecb to group 38
[    0.440785] iommu: Adding device 15810000.se to group 39
[    0.441067] iommu: Adding device 15820000.se to group 40
[    0.441372] iommu: Adding device 15830000.se to group 41
[    0.442089] iommu: Adding device 15840000.se to group 42
[    0.442929] iommu: Adding device smmu_test to group 43
[    0.443701] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c10000
[    0.443722] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[    0.443763] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[    0.443780] mc: mapped MMIO address: 0xffffff800b110000 -> 0x2c40000
[    0.443795] mc: mapped MMIO address: 0xffffff800b130000 -> 0x2c50000
[    0.443808] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.443822] mc-err: mcerr ops are set to t18x
[    0.444082] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[    0.445529] iommu: Adding device 3530000.xhci to group 44
[    0.445554] arm-smmu: forcing sodev map for 3530000.xhci
[    0.446295] iommu: Adding device 3550000.xudc to group 45
[    0.446316] arm-smmu: forcing sodev map for 3550000.xudc
[    0.447695] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.447707] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.448451] iommu: Adding device 17000000.gp10b to group 46
[    0.449808] tegra-reset 5000000.clock: registered 193 resets.
[    0.452370] iommu: Adding device d000000.bpmp to group 47
[    0.452681] bpmp: ping status is 0
[    0.452818] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[    0.456035] bpmp d000000.bpmp: probe ok
[    0.459631] iommu: Adding device 2600000.dma to group 48
[    0.461108] GPIO line 456 (camera-control-output-low) hogged as output/low
[    0.461142] GPIO line 461 (camera-control-output-high) hogged as output/high
[    0.461169] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[    0.461217] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[    0.461284] GPIO line 460 (uart3_select) hogged as output/high
[    0.461590] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[    0.467568] GPIO line 267 (backlight-enable) hogged as output/low
[    0.467822] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[    0.470146] iommu: Adding device 10003000.pcie-controller to group 49
[    0.470173] arm-smmu: forcing sodev map for 10003000.pcie-controller
[    0.470579] iommu: Adding device sound to group 50
[    0.471046] iommu: Adding device 3510000.hda to group 51
[    0.482548] iommu: Adding device c1a0000.aon to group 52
[    0.483166] vdd-ac-bat: 5000 mV
[    0.483686] vdd-hdmi: 5000 mV
[    0.483937] vdd-usb0-5v: 5000 mV
[    0.484209] vdd-usb1-5v: 5000 mV
[    0.484495] en-vdd-ts-1v8: 1800 mV
[    0.484746] en-vdd-ts-hv-3v3: 3300 mV
[    0.484986] en-vdd-disp-3v3: 3300 mV
[    0.485276] en-mdm-pwr-3v7: 3700 mV
[    0.485708] en-vdd-disp-1v8: 1800 mV
[    0.485970] en-vdd-cam-hv-2v8: 2800 mV
[    0.486221] en-vdd-cam-1v2: 1200 mV
[    0.486503] vdd-fan: 5000 mV
[    0.486847] dis-vdd-1v2: 1200 mV
[    0.487209] vdd-usb2-5v: 5000 mV
[    0.487594] en-vdd-sys: 1200 mV
[    0.487829] vdd-1v8-ap: 1800 mV
[    0.497258] random: fast init done
[    0.518499] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.523936] eventlib_kernel: keventlib is initialized, test id: 0
[    0.524413] SCSI subsystem initialized
[    0.524630] libata version 3.00 loaded.
[    0.524852] usbcore: registered new interface driver usbfs
[    0.524893] usbcore: registered new interface driver hub
[    0.524991] usbcore: registered new device driver usb
[    0.529259] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (pca9554)
[    0.531060] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip3 (pca9554)
[    0.532828] gpiochip_setup_dev: registered GPIOs 232 to 239 on device: gpiochip4 (pca9554)
[    0.544385] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.549443] vddio-ddr: at 1125 mV
[    0.553278] avdd_dsi_csi: 1200 mV
[    0.557036] vdd-1v8: 1800 mV
[    0.561035] vdd-3v3-sys: 3300 mV
[    0.561910] spmic-ldo0: at 1800 mV
[    0.562630] spmic-ldo1: at 800 mV
[    0.565032] vddio-3v3: 3300 mV
[    0.565651] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.569033] vdd-rtc: at 800 mV
[    0.569677] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[    0.573032] spmic-ldo6: at 1500 mV
[    0.577031] vdd-pex-1v00: 1000 mV
[    0.577719] dvdd-pex: 1000 mV
[    0.578254] GPIO line 229 (spmic_gpio_input) hogged as input
[    0.578406] GPIO line 230 (spmic_gpio_input) hogged as input
[    0.578618] gpiochip_setup_dev: registered GPIOs 224 to 231 on device: gpiochip5 (max77620-gpio)
[    0.580693] max77620 4-003c: max77620 probe successful
[    0.581139] media: Linux media interface: v0.10
[    0.581166] Linux video capture interface: v2.00
[    0.584814] pps_core: LinuxPPS API ver. 1 registered
[    0.584818] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.584833] PTP clock support registered
[    0.585236] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.585253] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.587072] tegra_fiq_debugger_init: found FIQ source (IRQ 385)
[    0.591284] trusty trusty: trusty version: Built: 21:17:07 Aug 12 2019
[    0.591297] trusty trusty: selected api version: 3 (requested 3)
[    0.592371] Advanced Linux Sound Architecture Driver Initialized.
[    0.592837] Bluetooth: Core ver 2.22
[    0.592885] NET: Registered protocol family 31
[    0.592890] Bluetooth: HCI device and connection manager initialized
[    0.592901] Bluetooth: HCI socket layer initialized
[    0.592909] Bluetooth: L2CAP socket layer initialized
[    0.592933] Bluetooth: SCO socket layer initialized
[    0.593914] en-vdd-sd: 3300 mV
[    0.594311] vdd-3v3: 3300 mV
[    0.594659] en-vdd-vcm-2v8: 2800 mV
[    0.594967] vdd-sys-bl: 3300 mV
[    0.598299] camchar: rtcpu character device driver loaded
[    0.598857] gpio tegra-gpio wake53 for gpio=159(X:7)
[    0.600904] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[    0.603058] clocksource: Switched to clocksource arch_sys_counter
[    0.645239] VFS: Disk quotas dquot_6.6.0
[    0.645448] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.646032] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.646933] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x000000026c600000,195035136
[    0.646945] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[    0.646953] nvmap_page_pool_init: Total RAM pages: 1961161
[    0.646960] nvmap_page_pool_init: nvmap page pool size: 245145 pages (957 MB)
[    0.647304] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.647645] misc nvmap: created heap vpr base 0x000000026c600000 size (190464KiB)
[    0.650980] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    0.662394] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.662574] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.662967] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.663106] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.663236] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[    0.663359] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    0.663543] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[    0.663794] la/ptsa driver initialized.
[    0.663807] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[    0.663812] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[    0.664968] NET: Registered protocol family 2
[    0.666931] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.667667] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.668451] TCP: Hash tables configured (established 65536 bind 65536)
[    0.668511] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.668644] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.669476] NET: Registered protocol family 1
[    0.670551] RPC: Registered named UNIX socket transport module.
[    0.670557] RPC: Registered udp transport module.
[    0.670562] RPC: Registered tcp transport module.
[    0.670566] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.670586] PCI: CLS 0 bytes, default 64
[    0.670818] Trying to unpack rootfs image as initramfs...
[    0.866288] Freeing initrd memory: 5432K
[    0.885719] host1x 13e10000.host1x: initialized
[    0.887491] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.891148] audit: initializing netlink subsys (disabled)
[    0.891185] audit: type=2000 audit(0.784:1): initialized
[    0.891749] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.902924] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.905544] ntfs: driver 2.1.32 [Flags: R/W].
[    0.907281] 9p: Installing v9fs 9p2000 file system support
[    0.913640] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.913813] io scheduler noop registered
[    0.914415] io scheduler cfq registered (default)
[    0.919263] gic 2a41000.agic-controller: GIC IRQ controller registered
[    0.983395] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[    1.023966] iommu: Adding device 2993000.adsp to group 54
[    1.025196] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    1.028246] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[    1.031553] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.032709] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    1.033754] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    1.034792] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.037026] tegra-pcie 10003000.pcie-controller: 1x1, 1x1, 1x1 configuration
[    1.038026] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[    1.038365] tegra-pcie 10003000.pcie-controller: probing port 0, using 1 lanes
[    1.038457] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.038674] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    1.038686] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=750000, max_bw=4687500
[    1.040628] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[    1.041999] tsec 15500000.tsec: initialized
[    1.042952] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[    1.043452] tsec 15100000.tsecb: initialized
[    1.046722] nvdec 15480000.nvdec: initialized
[    1.052600] falcon 15340000.vic: initialized
[    1.054164] falcon 154c0000.nvenc: initialized
[    1.055777] falcon 15380000.nvjpg: initialized
[    1.059315] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    1.061068] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    1.062689] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    1.064319] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    1.065873] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    1.067461] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    1.068997] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    1.070493] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    1.073830] tegradccommon 15200000.dc_common: host1x channel mapped
[    1.073844] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    1.073878] tegradccommon 15200000.dc_common: dma mapping done
[    1.074891] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/dsi
[    1.075175] tegradc 15200000.nvdisplay: No hpd-gpio in DT
[    1.075195] tegradc 15200000.nvdisplay: parse_disp_default_out: No parent clk. Using default clk
[    1.075224] tegradc 15200000.nvdisplay: DT parsed successfully
[    1.075245] tegradc 15200000.nvdisplay: Display dc.ffffff800b4a0000 registered with id=0
[    1.084272] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[    1.084281] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[    1.084286] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[    1.084588] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    1.084599] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    1.086115] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[    1.087196] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    1.087958] tegradc 15200000.nvdisplay: DSI: HS clock rate is 121500
[    1.088128] kfuse 3830000.kfuse: initialized
[    1.089830] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.089946] tegradc 15200000.nvdisplay: probed
[    1.095411] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.098500] console [ttyS0] disabled
[    1.098576] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[    1.098634] console [ttyS0] enabled
[    1.100295] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[    1.101440] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[    1.101742] serial-tegra 3130000.serial: RX in PIO mode
[    1.102071] Console: switching to colour frame buffer device 100x37
[    1.102124] tegradc 15200000.nvdisplay: fb registered
[    1.103854] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    1.104236] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    1.104279] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[    1.105596] [drm] Initialized
[    1.105686] sn65dsi83 0-002c: sn65dsi83_probe
[    1.114966] sn65dsi83 0-002c: failed to parse enable panel gpio
[    1.115007] sn65dsi83 0-002c: enpoint: /i2c@3160000/sn65dsi84@2c/port/endpoint host_node: /mipi_dsi_bridge
[    1.134878] sn65dsi83 0-002c: sn65dsi83_brg_power_on
[    1.371122] sn65dsi83 0-002c: sn65dsi83_brg_stop_stream
[    1.382390] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x01
[    1.395623] sn65dsi83 0-002c: CHA (0xe5) = 0x01
[    1.405316] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x0d data 0x00
[    1.443523] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[    1.457123] sn65dsi83 0-002c: sn65dsi83_brg_power_off
[    1.467625] sn65dsi83 0-002c: sn65dsi83_brg_power_on
[    1.468722] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.495610] sn65dsi83 0-002c: sn65dsi83_read: read reg 0x09 data 0x00
[    1.508807] sn65dsi83 0-002c: sn65dsi83_brg_reset
[    1.518466] sn65dsi83 0-002c: Video param: width: 800 height: 600 pixclk: 40000000
[    1.518472] sn65dsi83 0-002c: Starting stream in non-DRM mode
[    1.518477] sn65dsi83 0-002c: sn65dsi83_brg_setup
[    1.528119] sn65dsi83 0-002c: DSI clock [ 120000000 ] Hz
[    1.528126] sn65dsi83 0-002c: Resolution [ 800 x 600 ] Hz
[    1.528522] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x09 data 0x00
[    1.542465] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x0d data 0x00
[    1.556042] sn65dsi83 0-002c: lvds_clk=40000000 lvds_clk_range=0x1
[    1.556438] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x0a data 0x03
[    1.570399] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x12 data 0x18
[    1.584370] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x13 data 0x00
[    1.597950] sn65dsi83 0-002c: dsi_clk_range=0x18
[    1.597957] sn65dsi83 0-002c: dsi_clk_div=0x2
[    1.598352] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x0b data 0x10
[    1.612437] sn65dsi83 0-002c: sn65dsi83_read: read reg 0x10 data 0x26
[    1.626047] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x10 data 0x26
[    1.640010] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x11 data 0x00
[    1.653979] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x18 data 0x7c
[    1.667925] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x19 data 0x00
[    1.681894] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x1a data 0x03
[    1.695866] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x1b data 0x00
[    1.709826] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x28 data 0x21
[    1.723795] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x29 data 0x00
[    1.737763] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x2a data 0x00
[    1.751723] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x2b data 0x00
[    1.765657] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x20 data 0x20
[    1.779597] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x21 data 0x03
[    1.793525] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x22 data 0x00
[    1.807462] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x23 data 0x00
[    1.821424] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x24 data 0x58
[    1.835362] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x25 data 0x02
[    1.849302] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x26 data 0x00
[    1.863236] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x27 data 0x00
[    1.873045] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.877176] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x2c data 0x0d
[    1.891119] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x2d data 0x00
[    1.905074] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x2e data 0x00
[    1.919012] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x2f data 0x00
[    1.933057] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x30 data 0x02
[    1.947065] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x31 data 0x00
[    1.961010] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x32 data 0x00
[    1.974945] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x33 data 0x00
[    1.988909] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x34 data 0x26
[    2.002863] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x36 data 0x04
[    2.016803] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x35 data 0x00
[    2.030745] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x37 data 0x00
[    2.044682] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x38 data 0xdc
[    2.058617] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x3a data 0x18
[    2.072580] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x39 data 0x00
[    2.086590] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x3b data 0x00
[    2.100526] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x3c data 0x00
[    2.114459] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x3d data 0x00
[    2.128395] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x3e data 0x00
[    2.142322] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[    2.155891] sn65dsi83 0-002c: sn65dsi83_brg_start_stream
[    2.167163] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x0d data 0x01
[    2.207491] sn65dsi83 0-002c: sn65dsi83_write: write reg 0x09 data 0x01
[    2.221566] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x81
[    2.234752] sn65dsi83 0-002c: CHA err 1 (0xe5) = 0x81
[    2.245484] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[    2.277362] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    2.279381] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[    2.463630] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x00
[    2.476827] sn65dsi83 0-002c: CHA err2 (0xe5) = 0x00
[    2.486994] sn65dsi83 0-002c: Start check task /i2c@3160000/sn65dsi84@2c
[    2.487205] Check thread: sn65dsi84-0[PID = 1352] ptr: 0xffffffc1df7af800 client: 0xffffffc1dfd85800
[    2.498298] brd: module loaded
[    2.503541] loop: module loaded
[    2.503752] tegra_profiler: version: 1.134, samples/io: 47/26
[    2.503888] tegra_profiler: auth: init
[    2.504429] nct1008_nct72 7-004c: starting parse dt
[    2.504581] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[    2.504604] nct1008_nct72 7-004c: success parsing dt
[    2.504725] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[    2.504814] THERMAL EST: found 3 subdevs
[    2.504821] THERMAL EST num_resources: 0
[    2.504828] [THERMAL EST subdev 0]
[    2.504844] [THERMAL EST subdev 1]
[    2.504858] [THERMAL EST subdev 2]
[    2.505188] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[    2.505193] THERMAL EST: thz register success.
[    2.505401] THERMAL EST: end of probe, return err: 0
[    2.506466] hisi_sas: driver version v1.6
[    2.510983] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[    2.511009] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[    2.512307] scsi host0: tegra_ahci
[    2.513204] scsi host1: tegra_ahci
[    2.513351] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[    2.513357] ata2: DUMMY
[    2.519610] libphy: Fixed MDIO Bus: probed
[    2.520072] tun: Universal TUN/TAP device driver, 1.6
[    2.520077] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.521506] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.521512] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.521560] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    2.521565] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.521596] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    2.521600] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.521643] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    2.521647] Copyright(c) 1999 - 2017 Intel Corporation.
[    2.523291] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[    2.526746] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 10 77 81
[    2.526848] libphy: dwc_phy: probed
[    2.527314] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[    2.529621] PPP generic driver version 2.4.2
[    2.529769] PPP BSD Compression module registered
[    2.529774] PPP Deflate Compression module registered
[    2.529788] PPP MPPE Compression module registered
[    2.529792] NET: Registered protocol family 24
[    2.529853] usbcore: registered new interface driver r8152
[    2.529887] usbcore: registered new interface driver asix
[    2.529923] usbcore: registered new interface driver ax88179_178a
[    2.529950] usbcore: registered new interface driver cdc_ether
[    2.529980] usbcore: registered new interface driver net1080
[    2.530008] usbcore: registered new interface driver cdc_subset
[    2.530033] usbcore: registered new interface driver zaurus
[    2.530075] usbcore: registered new interface driver cdc_ncm
[    2.530198] VFIO - User Level meta-driver version: 0.3
[    2.531384] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.531397] ehci-pci: EHCI PCI platform driver
[    2.531428] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.531435] ohci-pci: OHCI PCI platform driver
[    2.531468] ohci-platform: OHCI generic platform driver
[    2.535716] tegra-xusb 3530000.xhci: No USB port has OTG_CAP
[    2.537041] nct1008_nct72 7-004c: LOC shutdown limit 107
[    2.537543] nct1008_nct72 7-004c: EXT shutdown limit 107
[    2.538071] usbcore: registered new interface driver uas
[    2.538110] usbcore: registered new interface driver usb-storage
[    2.538176] usbcore: registered new interface driver usbserial
[    2.538198] usbcore: registered new interface driver ch341
[    2.538219] usbserial: USB Serial support registered for ch341-uart
[    2.538239] usbcore: registered new interface driver cp210x
[    2.538257] usbserial: USB Serial support registered for cp210x
[    2.538279] usbcore: registered new interface driver ftdi_sio
[    2.538297] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.538319] usbcore: registered new interface driver option
[    2.538336] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.538358] usbcore: registered new interface driver pl2303
[    2.538376] usbserial: USB Serial support registered for pl2303
[    2.539084] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[    2.542504] tegra-xudc-new 3550000.xudc: device count: 1
[    2.543565] tegra-xudc-new 3550000.xudc: vbus state: 0
[    2.543594] tegra-xudc-new 3550000.xudc: entering ELPG
[    2.544453] tegra-xudc-new 3550000.xudc: entering ELPG done
[    2.544870] mousedev: PS/2 mouse device common for all mice
[    2.544971] usbcore: registered new interface driver xpad
[    2.570296] nct1008_nct72 7-004c: initial LOC temp: 29000
[    2.570603] nct1008_nct72 7-004c: initial EXT temp: 31250
[    2.571222] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[    2.571549] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[    2.571736] nct1008_nct72 7-004c: nct1008_probe: initialized
[    2.623084] tegra-xusb 3530000.xhci: xHCI Host Controller
[    2.623101] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[    2.623819] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[    2.623849] tegra-xusb 3530000.xhci: irq 69, io mem 0x03530000
[    2.623974] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.623978] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.623982] usb usb1: Product: xHCI Host Controller
[    2.623986] usb usb1: Manufacturer: Linux 4.9.140+ xhci-hcd
[    2.623989] usb usb1: SerialNumber: 3530000.xhci
[    2.624371] hub 1-0:1.0: USB hub found
[    2.624400] hub 1-0:1.0: 4 ports detected
[    2.624727] tegra-xusb 3530000.xhci: xHCI Host Controller
[    2.624734] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[    2.624853] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    2.624857] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.624860] usb usb2: Product: xHCI Host Controller
[    2.624864] usb usb2: Manufacturer: Linux 4.9.140+ xhci-hcd
[    2.624867] usb usb2: SerialNumber: 3530000.xhci
[    2.625183] hub 2-0:1.0: USB hub found
[    2.625208] hub 2-0:1.0: 3 ports detected
[    2.675515] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    2.677439] rtc rtc1: alarm rtc device
[    2.677457] rtc-pcf85063 0-0051: rtc core: registered rtc-pcf85063 as rtc1
[    2.677850] i2c /dev entries driver
[    2.680272] imx219 2-0010: tegracam sensor driver:imx219_v2.0.6
[    2.681073] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[    2.704054] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    2.704118] imx219 2-0010: imx219_board_setup: error during i2c read probe (-121)
[    2.719616] imx219 2-0010: board setup failed
[    2.728688] imx219: probe of 2-0010 failed with error -121
[    2.729659] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    2.735439] parse_throttle_dt_data: Num cap clks = 4
[    2.735447] parse_throttle_dt_data: clk=mcpu type=1
[    2.735453] parse_throttle_dt_data: clk=bcpu type=2
[    2.735463] parse_throttle_dt_data: clk=gpu type=4
[    2.735468] parse_throttle_dt_data: clk=emc type=3
[    2.736491] tegra_throttle_probe: probe successful. #cdevs=4
[    2.737112] FAN dev name: pwm-fan
[    2.737171] FAN:gpio request success.
[    2.737208] FAN: can't find tach_gpio
[    2.737245] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    2.737494] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[    2.737501] pwm_fan_driver pwm-fan: tach period: 1000
[    2.737881] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    2.737889] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    2.737895] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    2.737901] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    2.737906] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    2.737940] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    2.737946] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    2.737951] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    2.737959] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    2.737965] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    2.739706] device-mapper: uevent: version 1.0.3
[    2.740703] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.745479] cpufreq: platform driver Initialization: pass
[    2.746065] cpuidle: Initializing cpuidle driver init for Denver cluster
[    2.746175] cpuidle: Initializing cpuidle driver init for A57 cluster
[    2.746934] sdhci: Secure Digital Host Controller Interface driver
[    2.746938] sdhci: Copyright(c) Pierre Ossman
[    2.746941] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.748473] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    2.750429] CMDQ: cmdq_platfm_init successful
[    2.751531] CQE: CMD_TIMING bit set for R1B DCMD
[    2.753360] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    2.759245] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    2.759291] sdhci-tegra 3400000.sdhci: Got WP GPIO
[    2.760789] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    2.762664] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 256
[    2.767615] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    2.768812] tegra-se-nvhost 15810000.se: initialized
[    2.769881] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    2.770787] tegra-se-nvhost 15820000.se: initialized
[    2.771748] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    2.772526] tegra-se-nvhost 15830000.se: initialized
[    2.773317] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    2.773989] tegra-se-nvhost 15840000.se: initialized
[    2.774877] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    2.775150] hidraw: raw HID events driver (C) Jiri Kosina
[    2.776032] usbcore: registered new interface driver usbhid
[    2.776034] usbhid: USB HID core driver
[    2.783043] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    2.785949] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[    2.786209] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    2.786385] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[    2.786774] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[    2.787981] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[    2.788070] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[    2.788142] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[    2.788208] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[    2.788348] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[    2.788829] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[    2.788834] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    2.789684] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[    2.791363] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    2.791800] tegra186-aondbg aondbg: aondbg driver probe() OK
[    2.791960] register_ari_mca_banks: Registered MCA ROC:IOB
[    2.792026] register_ari_mca_banks: Registered MCA ROC:CCE
[    2.792338] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792341] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[    2.792344] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    2.792394] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792396] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[    2.792398] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    2.792454] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792456] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[    2.792458] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    2.792506] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792508] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[    2.792510] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    2.792558] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792560] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[    2.792562] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    2.792607] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792611] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[    2.792613] tegra18-bridge 2100000.axip2p: bridge probed OK
[    2.792658] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792662] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[    2.792664] tegra18-bridge 2110000.axip2p: bridge probed OK
[    2.792709] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792713] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[    2.792715] tegra18-bridge 2120000.axip2p: bridge probed OK
[    2.792758] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792763] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[    2.792764] tegra18-bridge 2130000.axip2p: bridge probed OK
[    2.792806] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792809] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[    2.792811] tegra18-bridge 2140000.axip2p: bridge probed OK
[    2.792854] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792859] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[    2.792860] tegra18-bridge 2150000.axip2p: bridge probed OK
[    2.792905] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792910] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[    2.792912] tegra18-bridge 2160000.axip2p: bridge probed OK
[    2.792960] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.792965] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[    2.792967] tegra18-bridge 2170000.axip2p: bridge probed OK
[    2.793011] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.793016] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[    2.793018] tegra18-bridge 2180000.axip2p: bridge probed OK
[    2.793061] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    2.793066] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[    2.793067] tegra18-bridge 2190000.axip2p: bridge probed OK
[    2.793120] **** A57 ECC: Enabled
[    2.793122] tegra18_a57_serr_init: on CPU 3 a A57 Core
[    2.793180] tegra18x_actmon d230000.actmon: in actmon_register()...
[    2.793659] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    2.794086] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    2.794203] denver_knobs_init:MTS_VERSION:43068234
[    2.795120] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    2.795705] nvpmodel: initialized successfully
[    2.797592] trusty-virtio trusty:virtio: initializing
[    2.797690] trusty_ipc virtio0: vring0: va(pa)  ffffffc1db2b4000(0) qsz 32 notifyid 1
[    2.797697] trusty_ipc virtio0: vring1: va(pa)  ffffffc1db2b6000(0) qsz 32 notifyid 2
[    2.797760] trusty-virtio trusty:virtio: initializing done
[    2.797851] trusty_ipc virtio0: is online
[    2.799901] usbcore: registered new interface driver snd-usb-audio
[    2.807070] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    2.808230] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    2.808514] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    2.811173] gpio tegra-gpio wake71 for gpio=125(P:5)
[    2.811227] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    2.826388] ata1: SATA link down (SStatus 0 SControl 300)
[    2.883362] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    2.897842] mmc0: periodic cache flush enabled
[    2.897859] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    2.898411] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[    2.898668] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[    2.899887] OPE platform probe
[    2.899953] OPE platform probe successful
[    2.901872] tegra-asoc: sound: This is a dummy codec
[    2.902965] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[    2.903224] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[    2.907188]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[    2.946258] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    2.946330] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    2.946398] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    2.946462] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    2.946529] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    2.946595] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    2.946661] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    2.946729] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    2.946796] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    2.946860] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    2.946931] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    2.946997] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    2.947086] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    2.947169] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    2.947235] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    2.947301] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    2.947365] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    2.947430] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    2.947499] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    2.947563] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    2.951084] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[    2.970500] u32 classifier
[    2.970506]     Actions configured
[    2.970584] Initializing XFRM netlink socket
[    2.972190] NET: Registered protocol family 10
[    2.972506] usb 1-3: New USB device found, idVendor=05e3, idProduct=0608
[    2.972511] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.972514] usb 1-3: Product: USB2.0 Hub
[    2.973309] hub 1-3:1.0: USB hub found
[    2.973436] NET: Registered protocol family 17
[    2.973452] NET: Registered protocol family 15
[    2.973593] hub 1-3:1.0: 4 ports detected
[    2.973660] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.973729] Bluetooth: RFCOMM socket layer initialized
[    2.973745] Bluetooth: RFCOMM ver 1.11
[    2.973751] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.973758] Bluetooth: HIDP socket layer initialized
[    2.973778] 9pnet: Installing 9P2000 support
[    2.973822] Key type dns_resolver registered
[    2.974233] Registered cp15_barrier emulation handler
[    2.974250] Registered setend emulation handler
[    2.975976] bootconsole [uart8250] disabled
[    2.976018] registered taskstats version 1
[    2.979605] isp 15600000.isp: initialized
[    2.984250] nvcsi 150c0000.nvcsi: initialized
[    2.989587] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[    2.989683] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[    2.989766] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[    2.989949] input: gpio-keys as /devices/gpio-keys/input/input2
[    2.990801] tegra-vi4 15700000.vi: initialized
[    2.991606] rtc-pcf85063 0-0051: setting system clock to 2021-12-06 21:19:11 UTC (1638825551)
[    2.992403] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[    2.992562] mmcblk mmc0:0001: Card claimed for testing.
[    3.029544] bpmp: mounted debugfs mirror
[    3.031189] bwmgr: missing cdev-type property
[    3.036476] en-vdd-sys: disabling
[    3.036488] spmic-ldo0: disabling
[    3.036754] spmic-ldo1: disabling
[    3.036936] en-vdd-sd: disabling
[    3.036940] vdd-3v3: disabling
[    3.036943] en-vdd-vcm-2v8: disabling
[    3.036948] ALSA device list:
[    3.036952]   #0: tegra-hda at 0x3518000 irq 382
[    3.036956]   #1: tegra-snd-t186ref-mobile-rt565x
[    3.039124] Freeing unused kernel memory: 8640K
[    3.080824] Root device found: mmcblk0p1
[    3.082770] Found dev node: /dev/mmcblk0p1
[    3.091086] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[    3.107449] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    3.108650] Rootfs mounted over mmcblk0p1
[    3.142819] Switching from initrd to actual rootfs
[    3.267056] usb 1-3.2: new low-speed USB device number 3 using tegra-xusb
[    3.296685] usb 1-3.2: New USB device found, idVendor=046d, idProduct=c31c
[    3.296689] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.296693] usb 1-3.2: Product: USB Keyboard
[    3.296696] usb 1-3.2: Manufacturer: Logitech
[    3.302097] input: Logitech USB Keyboard as /devices/3530000.xhci/usb1/1-3/1-3.2/1-3.2:1.0/0003:046D:C31C.0001/input/input3
[    3.349506] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.363381] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3530000.xhci-3.2/input0
[    3.370203] input: Logitech USB Keyboard as /devices/3530000.xhci/usb1/1-3/1-3.2/1-3.2:1.1/0003:046D:C31C.0002/input/input4
[    3.394185] cgroup: cgroup2: unknown option "nsdelegate"
[    3.418982] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    3.422024] systemd[1]: Detected architecture arm64.
[    3.427203] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3530000.xhci-3.2/input1
[    3.493463] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[    3.495478] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[    3.507059] usb 1-3.3: new low-speed USB device number 4 using tegra-xusb
[    3.511830] systemd[1]: Set hostname to <tegra-ubuntu>.
[    3.531100] usb 1-3.3: New USB device found, idVendor=046d, idProduct=c05a
[    3.531105] usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.531107] usb 1-3.3: Product: USB Optical Mouse
[    3.531109] usb 1-3.3: Manufacturer: Logitech
[    3.534072] input: Logitech USB Optical Mouse as /devices/3530000.xhci/usb1/1-3/1-3.3/1-3.3:1.0/0003:046D:C05A.0003/input/input5
[    3.534343] hid-generic 0003:046D:C05A.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3530000.xhci-3.3/input0
[    3.613166] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    3.613192] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    3.703260] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[    3.703265] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    3.703268] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[    3.703271] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[    3.703274] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.703303] pci 0000:00:02.0: [10de:10e6] type 01 class 0x060400
[    3.703411] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    3.703565] iommu: Adding device 0000:00:02.0 to group 55
[    3.703572] arm-smmu: forcing sodev map for 0000:00:02.0
[    3.703638] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.703766] pci 0000:01:00.0: [1ac1:089a] type 00 class 0x0000ff
[    3.703825] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit pref]
[    3.703863] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit pref]
[    3.704332] iommu: Adding device 0000:01:00.0 to group 56
[    3.704335] arm-smmu: forcing sodev map for 0000:01:00.0
[    3.704373] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    3.704410] pci 0000:00:02.0: BAR 15: assigned [mem 0x48000000-0x481fffff 64bit pref]
[    3.704414] pci 0000:01:00.0: BAR 2: assigned [mem 0x48000000-0x480fffff 64bit pref]
[    3.704446] pci 0000:01:00.0: BAR 0: assigned [mem 0x48100000-0x48103fff 64bit pref]
[    3.704477] pci 0000:00:02.0: PCI bridge to [bus 01]
[    3.704486] pci 0000:00:02.0:   bridge window [mem 0x48000000-0x481fffff 64bit pref]
[    3.704683] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    3.704686] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    3.704692] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    3.704762] aer 0000:00:02.0:pcie002: service driver aer loaded
[    3.704935] apex 0000:01:00.0: enabling device (0000 -> 0002)
[    3.807121] random: systemd: uninitialized urandom read (16 bytes read)
[    3.810594] systemd[1]: Created slice User and Session Slice.
[    3.810971] random: systemd: uninitialized urandom read (16 bytes read)
[    3.811029] systemd[1]: Reached target User and Group Name Lookups.
[    3.811203] random: systemd: uninitialized urandom read (16 bytes read)
[    3.811509] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.811624] systemd[1]: Reached target Swap.
[    3.819035] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.866984] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    4.209458] systemd-journald[2343]: Received request to flush runtime journal from PID 1
[    4.869048] using random self ethernet address
[    4.873693] using random host ethernet address
[    4.917397] Mass Storage Function, version: 2009/09/11
[    4.917409] LUN: removable file: (no medium)
[    4.925480] using random self ethernet address
[    4.931213] using random host ethernet address
[    4.964858] rndis0: HOST MAC da:41:a5:a4:19:00
[    4.965207] rndis0: MAC da:41:a5:a4:19:01
[    4.966046] usb0: HOST MAC da:41:a5:a4:19:02
[    4.966071] usb0: MAC da:41:a5:a4:19:03
[    4.966090] tegra-xudc-new 3550000.xudc: exiting ELPG
[    4.967598] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    4.967617] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[    4.967644] tegra-xudc-new 3550000.xudc: entering ELPG
[    4.968394] tegra-xudc-new 3550000.xudc: entering ELPG done
[    4.968411] tegra-xudc-new 3550000.xudc: exiting ELPG
[    4.969419] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    4.969436] tegra-xudc-new 3550000.xudc: entering ELPG
[    4.970181] tegra-xudc-new 3550000.xudc: entering ELPG done
[    4.976218] l4tbr0: port 1(rndis0) entered blocking state
[    4.976222] l4tbr0: port 1(rndis0) entered disabled state
[    4.976353] device rndis0 entered promiscuous mode
[    4.996879] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    5.010013] l4tbr0: port 2(usb0) entered blocking state
[    5.010020] l4tbr0: port 2(usb0) entered disabled state
[    5.010769] device usb0 entered promiscuous mode
[    5.018985] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    5.267612] random: crng init done
[    5.271022] random: 7 urandom warning(s) missed due to ratelimiting
[    5.524001] nvgpu: 17000000.gp10b             railgate_enable_store:283  [INFO]  railgate is disabled.
[    5.767103] Wake76 for irq=199
[    5.767107] Wake77 for irq=199
[    5.767108] Wake78 for irq=199
[    5.767110] Wake79 for irq=199
[    5.767111] Wake80 for irq=199
[    5.767112] Wake81 for irq=199
[    5.767113] Wake82 for irq=199
[    5.767153] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[    5.767157] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[    5.871227] usb usb2: usb_suspend_both: status 0
[    6.128309] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.208048] gpio tegra-gpio wake18 for gpio=101(M:5)
[    6.213730] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.371355] zram: Added device: zram0
[    6.375920] zram: Added device: zram1
[    6.388422] zram: Added device: zram2
[    6.391843] zram: Added device: zram3
[    6.393260] zram: Added device: zram4
[    6.395720] zram: Added device: zram5
[    6.442278] zram0: detected capacity change from 0 to 670613504
[    6.473305] Adding 654892k swap on /dev/zram0.  Priority:5 extents:1 across:654892k SS
[    6.485829] zram1: detected capacity change from 0 to 670613504
[    6.519326] Adding 654892k swap on /dev/zram1.  Priority:5 extents:1 across:654892k SS
[    6.533759] zram2: detected capacity change from 0 to 670613504
[    6.555489] Adding 654892k swap on /dev/zram2.  Priority:5 extents:1 across:654892k SS
[    6.565321] zram3: detected capacity change from 0 to 670613504
[    6.577284] Adding 654892k swap on /dev/zram3.  Priority:5 extents:1 across:654892k SS
[    6.581319] zram4: detected capacity change from 0 to 670613504
[    6.593154] Adding 654892k swap on /dev/zram4.  Priority:5 extents:1 across:654892k SS
[    6.596634] zram5: detected capacity change from 0 to 670613504
[    6.620564] Adding 654892k swap on /dev/zram5.  Priority:5 extents:1 across:654892k SS
[    7.731134] tegradc 15200000.nvdisplay: unblank
[    8.619713] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x00
[    8.626703] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[    8.783086] apex 0000:01:00.0: Apex performance not throttled due to temperature
[    8.956539] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[    8.957209] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.923321] fuse init (API version 7.26)
[   13.130278] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.130295] Bluetooth: BNEP socket layer initialized
[   13.570729] tegradc 15200000.nvdisplay: unblank
[   61.362844] tegradc 15200000.nvdisplay: blank - powerdown idx: 0
[   61.416428] tegradc 15200000.nvdisplay: blank - powerdown idx: 0
Please try to attach your log as text files. It will be more easier to use search.
If you upload 2~3 logs in your current way, then we don’t need to check, just keep scrolling the mouse…
OK, will do that later on
Edit: What I’m wondering: is there some function to call in the kernel which registers a display as being ‘virtual console enabled’? There has to be a way that the system knows it can use a certain display as a console.
See the attached files:
dmesg.txt (65.7 KB)
syslog (804.6 KB)
I can reproduce this issue too. Need to check what is going on with fbconsole.
Please add below patch to your fb.c driver and it shall work.
@@ -1298,7 +1301,10 @@ struct tegra_fb_info *tegra_fb_register(struct platform_device *ndev,
        info->pseudo_palette = pseudo_palette;
        info->screen_base = tegra_fb->win.virt_addr;
        info->screen_size = tegra_fb->fb_size;
-       info->state = FBINFO_STATE_SUSPENDED;
+       if(dc->out->type == TEGRA_DC_OUT_DSI)
+           info->state = FBINFO_STATE_RUNNING;
+       else
+           info->state = FBINFO_STATE_SUSPENDED;
        strlcpy(info->fix.id, "tegra_fb", sizeof(info->fix.id));
        info->fix.type          = FB_TYPE_PACKED_PIXELS;
        info->fix.visual        = FB_VISUAL_TRUECOLOR;
Wayne,
Sorry for getting back so late… I have tried your patch last week and it works. Many thanks for that!
The only remaining problem is that a black background shows as light gray. Blue and red background work just fine so that is not a major issue.
