Hi, I’m working in deepstream 5.0 with triton inference server. I’ve loaded a TensorFlow model for plates text recognition. The problem I’m facing is that after I load the model with the proper config for tensorflow_graphdef in Triton Server. The result that I get when I run deepstream-app -c config.txt is wrong. It should label the six letters on the plate, but instead of that, I get just one letter in the output label. First, the model I’m using a model which has a -1x24x94x3 input, and a 1x6 output. I can show you the graph if needed. Also, these are my config for triton and deepstream:
config.pbtxt
platform: “tensorflow_graphdef”
max_batch_size: 8
input [
data_type: TYPE_FP32
dims: [24, 94, 3 ]
output [
data_type: TYPE_INT32
dims: [ 6 ]
label_filename: “lpr_labels.txt”
source1_primary classifier_modified for my tensorflow model with RTSP
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=kitti-trtis
[tiled-display]
enable=1
rows=1
columns=1
#width=1280
#height=720
width=376
height=96
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://…/…/streams/lpr_complete_test.mp4
#uri=file://…/…/streams/classification_test_video.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
#(0): memtype_device - Memory type Device
#(1): memtype_pinned - Memory type Host Pinned
#(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
#set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
##Set muxer output width and height
#width=1280
#height=720
width=376
height=96
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
#config-file property is mandatory for any gie section.
#Other properties are optional and if set will override the properties set in
#the infer config file.
[primary-gie]
enable=1
#(0): nvinfer; (1): nvinferserver
plugin-type=1
#infer-raw-output-dir=trtis-output
batch-size=1
interval=0
gie-unique-id=1
#config-file=config_infer_primary_classifier_densenet_onnx.txt
#config-file=config_infer_primary_classifier_inception_graphdef_postprocessInDS.txt
#config-file=config_infer_primary_classifier_inception_graphdef_postprocessInTrtis.txt
config-file=config_infer_primary_classifier_lpr_model_postprocessInTrtis.txt
#config-file=config_infer_primary_classifier_lpr_saved_model.txt
[tests]
file-loop=1
config of primary gie:
infer_config {
unique_id: 5
gpu_ids: [0]
max_batch_size: 1
backend {
inputs: [ {
outputs: [
{name: “d_predictions”}
trt_is {
model_name: “lpr_model”
version: -1
model_repo {
root: “…/…/trtis_model_repo”
strict_model_config: true
tf_gpu_memory_fraction: 0.35
tf_disable_soft_placement: 0
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_NHWC
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 1
normalize {
scale_factor: 0.0078125
channel_offsets: [128, 128, 128]
postprocess {
trtis_classification {
topk: 1
threshold:0.1
input_control {
process_mode: PROCESS_MODE_FULL_FRAME
interval: 0
Any suggestions pls. Thank you.
**• Hardware Platform: Tesla T4 in Ubuntu server 18.04
**• DeepStream Versio: 5.0
**• NVIDIA GPU Driver Version (valid for GPU only): 450.51.06
