I noticed that insertion and harmonization have been performed in the article `Asset Harvester: Extracting 3D Assets from Autonomous Driving Logs for Simulation`, since the harveted 3d assets are normalized, hot to get the related true scales? I tried to insert a harvested vehicle gaussian ply in camera view, the size of vechile in rendered image mismatched which in original image. Thank you, looking forward for your reply.
The harvested gaussians.ply is deliberately in a normalized, object-local coordinate system. It is not a meter-scale scene object by itself.
For supported NuRec integration, do not derive scale from PLY bounds. Use the supplied pipeline:
python -m asset_harvester.utils.orient_gaussians_for_nurec \
--input-dir outputs/ncore_harvest \
--output-dir outputs/ncore_harvest_nurec
python asset_harvester/utils/generate_external_assets_metadata.py \
--input-dir outputs/ncore_harvest_nurec
Then package that directory using NuRec’s external-asset workflow.
