Hi, I’m working on developing an extension.
I’m having trouble implementing the Transformation UI.
Below is the code for the Transformation UI and a picture of the UI from the extension.
def _robot_transformation_frame(self):
properties = ["Translate", "Orient", "Scale"]
axis = ["X", "Y", "Z"]
colors = {"X": 0xFF5555AA, "Y": 0xFF76A371, "Z": 0xFFA07D4F}
with ui.VStack(spacing=8):
ui.Spacer(height=0)
for _property in properties:
with ui.HStack():
with ui.HStack():
ui.Label(_property, name="Transformation", width=50)
ui.Spacer()
for ax in axis:
default_value = 0.0 if _property in ["Translate", "Orient"] else 1.0
with ui.HStack():
with ui.ZStack(width=15):
ui.Rectangle(width=15, height=20, style={
"background_color": colors[ax],
"border_radius": 3,
"corner_flag": ui.CornerFlag.LEFT,
ui.Label(ax, name='transform_label', alignment=ui.Alignment.CENTER)
float_drag = ui.FloatDrag(name=_property, min=-1000000, max=1000000, step=0.01)
float_drag.model.set_value(default_value)
self._robot_transform_models.append(float_drag.model)
ui.Spacer(height=0)
ui.Button(
"Apply Transform",
height=50,
clicked_fn = self._apply_transform_callback,
style=BUTTON_BASE_STYLE)
ui.Button(
"Reset Transform",
height=50,
clicked_fn = self._reset_transform_callback,
def _apply_transform_callback(self):
# translate = Gf.Vec3d(
# self._robot_transform_models[0],
# self._robot_transform_models[1],
# self._robot_transform_models[2]
# rotate = Gf.Vec3d(
# self._robot_transform_models[3],
# self._robot_transform_models[4],
# self._robot_transform_models[5]
# scale = Gf.Vec3d(
# self._robot_transform_models[6],
# self._robot_transform_models[7],
# self._robot_transform_models[8]
translate = (
rotate = (
scale = (
print(f"Applying transform: Translate={translate}, Rotate={rotate}, Scale={scale}")
self.robot_importer._apply_transform(translate, rotate, scale)
def _apply_transform(self, translate, orient, scale):
prim = stage.GetPrimAtPath(self._get_prim_path())
if prim.IsValid():
xform = UsdGeom.XformCommonAPI(prim)
xform.SetTranslate(translate)
xform.SetRotate(Gf.Vec3f(*orient))
xform.SetScale(scale)
As shown in the picture, I want to change the translate, orient, and scale values in the simulation and apply them to a specific prim.
However, I don’t know how to apply these values in real-time.
It seems that the SimpleFloatModel does not have a method to get the current value. Can you help me figure out how to solve this problem?
