Hello
I installed two imx185 cameras on the jetson tx2.
I am trying to get streams from cameras but only one stream is received.
The current version of L4T is 28.1.
Any solution?
You will need to use the driver provided by the vendor of the IMX185 cameras. (Perhaps this is Leopard Systems?)
If their driver doesn’t support a certain feature (such as multiple devices at the same time) then you will have to wait for the vendor to update the drivers.
