GPU • DeepStream Version
6.1 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
11.6 • Issue Type( questions, new requirements, bugs)
new requirements • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
After Deepstream deployed yolov5, each number in the identification result was merged together and sent to kakfa as required, as shown in the figure below. The identification results are sent to kafka in a separate format T,T,3,1,2,2. The requirement is to encapsulate the identification results into two pieces of data, T31 and T22, and then send them to kafka.
