We have multiple Jetson Orin NX 16G SOM with outer packaging, but we can’t identify which one is equipped with Micron’s DDR.
How to identify whether the Jetson Orin NX SOM is equipped with Micron’s DDR on the outer packaging?
It is not possible to identify from label. You should apply PCN update to your software.
Where can we purchase the Orin NX SOM with Micron DDR?
We need it to verify our customized kernel with PCN update.
You may need to contact with local distributor to see if they can provide the Orin NX module with Micro memory samples for you to do the verification.
