I am designing a carrier board for the Jetson AGX Orin SOM. I noticed that the DP 1.4 and HDMI 2.1 interfaces share the same set of pins on the module.
My project requires simultaneous support for one DP output and one HDMI output. Since the native pins are shared, I am looking for the best architectural approach to achieve this.
Could you provide some recommendations on how to handle this? For instance:
Are there recommended bridge ICs or specific topologies (e.g., using DP MST or PCIe-to-Display controllers) that are compatible with the Orin?
Are there any known limitations or design considerations I should be aware of when implementing a secondary display output via non-native pins?
Any advice or reference designs would be greatly appreciated. Thanks!
Thank you for the clarification. I have a follow-up question regarding the architecture:
Instead of using a DP MST Hub, would it be feasible to use a DP Switch IC combined with a DP-to-HDMI bridge IC to achieve my goal of having one native DP 1.4 port and one switchable HDMI 2.1 port?
I am particularly concerned about two aspects:
Hardware Implementation: Is this switching topology viable in terms of signal integrity for DP 1.4 (HBR3)? Are there any critical layout constraints I should follow?
Driver and Firmware Support: Since this is a hardware-level switch, will it cause issues with Hot-plug detection (HPD) or EDID reading? Are there any specific requirements in the Device Tree (DTB) or driver configuration to ensure the system correctly handles the display output when switching between the native DP and the bridge IC?"
just to clarify — in your original post you mentioned simultaneous DP + HDMI output, but in your follow-up you referred to a switchable HDMI port. Could you confirm whether you need both displays active at the same time, or if switching between DP and HDMI one at a time is acceptable for your use case?
Thank you for pointing that out. I apologize for the confusion in my previous messages.
To clarify, my primary requirement is to have one native DP 1.4 port and one HDMI 2.1 port available.
Regarding the operation: Switching between them is acceptable for my use case. I do not need both displays to be active simultaneously. The goal is to have the flexibility to select either the DP output or the HDMI output depending on the application, using the hardware switch approach we discussed.
Could you confirm if the DP Switch IC + DP-to-HDMI bridge IC architecture is the recommended way to achieve this ‘one-at-a-time’ switching, and if there are any specific firmware or driver considerations for toggling between these two paths?"
From jetson point of view, we only support one kind of display mode on that only one port. If you want to switch mode, then you need to reflash the board.
For example, default setting is DP mode. If you want to switch to HDMI, then a full reflash is needed.
As for how you want to implement those switch or bridge, that is not ever validated on any of our side. We don’t guarantee if any problem would happen.
Thank you for the clarification. I understand that the port mode is fixed at the software/firmware level.
I would like to clarify if controlling the HPD (Hot-Plug Detect) signal would allow the system to re-initialize the port mode without a full reflash?
My concern is: If I implement a hardware switch for the HPD signal, can I trigger the Jetson to re-read the EDID and re-initialize the display interface as a different type (e.g., switching from DP to HDMI) while the system is running, or is a full system reboot/reflash strictly required for any mode change?"
I am designing a custom carrier board for the Jetson AGX Orin and need to support two displays: one native DP 1.4 and one HDMI 2.1, DP output is as default and HDMI 2.1 output can be switched . Since the native port cannot be dynamically switched (due to Pinmux/Reflash requirements), I am evaluating two possible architectures to achieve this.
Could you provide your expert opinion on the feasibility and stability of these two approaches for an industrial-grade product?
Option A: DP MST Hub + DP-to-HDMI Bridge IC
Architecture: Orin (Native DP) → MST Hub → DP-to-HDMI Bridge IC → HDMI Display.
Goal: Use the MST Hub to split the signal and the bridge IC for protocol conversion.
Concerns: I am worried about the complexity of the signal chain, EDID pass-through, HPD propagation, and whether the Jetson display driver can handle this downstream conversion reliably.
Option B: PCIe-based Display Expansion
Architecture: Use a PCIe-to-HDMI 2.1 controller (e.g., a discrete bridge IC or GPU) on an available PCIe slot.
Goal: Offload the secondary display output to the PCIe bus to keep the native DP port clean.
Concerns: I would like to know if this is the “standard” way to add a second display on Jetson platforms and if there are any driver/compatibility pitfalls I should be aware of.
My questions:
Which approach would you recommend for a reliable, production-grade industrial carrier board?
Are there any known limitations or specific driver requirements for either approach on Jetson Linux?
If Option B is preferred, are there any specific PCIe display controllers that have been validated with the Jetson AGX Orin?
It does not matter whether you need one display active at a time. To support dual monitor on Jetson Orin, MST hub is the only option. You could only try with option A.
There is no driver for PCIe based display on Jetson.
Thank you for the clarification. I understand that MST Hub is the only supported path for dual-display on the Jetson AGX Orin. I will proceed with the MST Hub architecture.
To ensure the stability of my industrial-grade carrier board, could you provide guidance on the following:
Validated MST Hubs: Are there any specific MST Hub chipsets (e.g., Synaptics VMM series) that NVIDIA has validated or recommends for use with the Jetson AGX Orin?
HPD/EDID Handling: Since MST Hubs can be sensitive to HPD/EDID timing, are there any recommended design practices or ‘best practices’ for the carrier board layout to ensure reliable detection of the two downstream displays?
Dual-Display Configuration: Is there any specific documentation or reference design for configuring the Device Tree to support MST-based dual-display output?
Power/Reset: Are there any requirements for the MST Hub’s power-on sequence or reset handling to ensure it initializes correctly during the Jetson boot process?"
We recommend first testing with a commercially available DP MST Hub device to verify functionality on the Jetson platform before proceeding with an on-board design. For the on-board chipset, any VESA DP-certified and HDMI-certified MST hub IC should work without major issues, as MST is a standard DisplayPort protocol.*
