Hi all,
I need to calculate the mean and standard deviation of the lines of a matrix (image) of bytes (0 - 255 values).
colums = x
lines = y
The code to calculate the mean is here:
[codebox]extern “C” int CalcThreasholds(unsigned int numLines, unsigned int pixelsPerLine)
cudaError_t cerror;
cudaMemcpy2D(f_d_threasholdslocal, pitchThreasholds, f_d_lines, pitchLines, pixelsPerLine*sizeof(CFPTYPE), numLines, cudaMemcpyDeviceToDevice);
for (unsigned int stride=2;(stride/2)<pixelsPerLine;stride*=2)
CalcDims(ceil(pixelsPerLine/(float)stride), numLines, &dimBlocksLines, &dimGridLines);
CalcThreasholdsGPUVR<<<dimGridLines, dimBlocksLines>>>(stride, pixelsPerLine, pitchThreasholds, f_d_threasholdslocal, f_d_threasholds_SumQ, f_d_threasholds);
cudaThreadSynchronize();
if ((cerror = cudaGetLastError()))
return cerror;
}[/codebox]
[codebox]global
void CalcThreasholdsGPUVR(unsigned int stride, unsigned int pixelsPerLine, size_t pitchTField, CFPTYPE *f_d_threasholdsField, CFPTYPE *f_d_threasholds_SumQ,CFPTYPE *f_d_threasholds)
unsigned int x = blockIdx.x*blockDim.x*stride + threadIdx.x*stride;
unsigned int y = blockIdx.y*blockDim.y + threadIdx.y;
if (((x%stride)==0) && ((x+stride/2)<pixelsPerLine))
((float*)((char*)f_d_threasholdsField+y*pitchTField))[x] += ((float*)((char*)f_d_threasholdsField+y*pitchTField))[x+stri
de/2];
__syncthreads();
if ((stride*2)>(pixelsPerLine*2))
f_d_threasholds[y] = ((float*)((char*)f_d_threasholdsField+y*pitchTField))[0] / (float)pixelsPerLine;
}[/codebox]
It works fine, but I need to calculate the standard deviation too, the equation is:
StdDev = SquareRoot( ( SumQ - (mean*mean)/pixelsPerLine ) ) / (1-pixelsPerLine ) External Image
SumQ += x*x (pixel x of line y)
Any idea? Thanks
