Even I build a python opencv with cuda and gpu enable, the time the Jetson Nano cost to calculate the dense optical flow of two frames cost 3 seconds. Any suggestion about which API or SDK should I use to build a dense optical flow program that enable to calculate the flow in around 5 ~ 10 FPS on Jetson Nano?
You could give a try to VPI: VPI - Vision Programming Interface: Algorithms
Jafet Chaves,
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Good to know, jet.code21. puffvayne, perhaps you could share your code to check if there are any parts where it can be optimized.
