After set tx2 nvpmodel to max-N and run jetson_clock.sh.
The fps increased 2-3 fps but accuracy looked no improve.
Could you explain more about the compilation selection?
how to make sure select sm_62?
Plus, we realized the preview quality might affect to the accuracy.
Is there a way to adjust the preview quality?
Did anyone compare the preview quality on TX1 and TX2?
I have set the Makefile.config CUDA_ARCH := -gencode arch=compute_63,code=sm_62 ,set NV Power Mode MAX-N sudo ./jetson_clock.sh ,but it did not work when I used the camera.Is there any other useful advice for me to improve the TX2 performance to 8.0fps (8.0fps is a value I’ve seen from other webpage) Thank you
