The output signal gain of HDMI output port 1 is low, and the single ended swing of differential signal is only about 200mv, which is less than the recommended value of 500mv in HDMI standard. Is there a way to achieve signal gain? If so, please provide specific implementation methods
Please check your board design to make sure it well follows the routing guideline in DG doc and do HDMI tuning based on the tuning guide doc in DLC. Jetson Download Center | NVIDIA Developer
