How to include "ring" and "time" fields in LiDAR PointCloud2 for LIO-SAM compatibility?
Isaac Sim Version
5.0.0
Operating System
Ubuntu 24.04
GPU Information
  • Model:5090
  • Driver Version:575
Topic Description
How to include “ring” and “time” fields in LiDAR PointCloud2 for LIO-SAM compatibility?
Detailed Description
Hi all,
I’m working on integrating LIO-SAM with Isaac Sim (version 5.0, ROS 2 Jazzy).
My setup:
  • Isaac Sim 5.0 on Ubuntu 24.04
  • ROS 2 Jazzy, running LIO-SAM
  • Robot model: Nova Carter example with /front_3d_lidar/lidar_points published to ROS2
Problem
The LiDAR point cloud from Isaac Sim only contains the following fields:
  • x, y, z, intensity
However, LIO-SAM expects additional fields:
  • ring (uint16, scan line ID)
  • time (float32, relative timestamp within the scan)
Without these fields, LIO-SAM immediately throws errors:
Error Messages
[lio_sam_imageProjection-2] [ERROR] [1757666494.917126170] [lio_sam_imageProjection]: Point cloud ring channel not available, please configure your point cloud data!
[lio_sam_imageProjection-2] [WARN] [1757666495.251477140] [lio_sam_imageProjection]: Point cloud timestamp not available, deskew function disabled, system will drift significantly!
[lio_sam_imageProjection-2] [INFO] [1757666495.251488505] [lio_sam_imageProjection]: Waiting for IMU data …
[INFO] [lio_sam_imageProjection-2]: process has finished cleanly [pid 504003]
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
[lio_sam_featureExtraction-3] [INFO] [1757667239.927635432] [rclcpp]: signal_handler(signum=2)
[lio_sam_mapOptimization-4] [INFO] [1757667239.927710938] [rclcpp]: signal_handler(signum=2)
[lio_sam_imuPreintegration-1] [INFO] [1757667239.927764771] [rclcpp]: signal_handler(signum=2)
[INFO] [lio_sam_featureExtraction-3]: process has finished cleanly [pid 504004]
[INFO] [lio_sam_mapOptimization-4]: process has finished cleanly [pid 504005]
[INFO] [lio_sam_imuPreintegration-1]: process has finished cleanly [pid 504002]
@me0608623 unfortunately, currently we don’t support this feature. Internally we have already created a request to add timestamp for lidar data. I will create one for ring data as well.
At the same time, you can try creating your customized omni graph node to publish timestamp and ring data for lidar Custom Python Nodes — Isaac Sim Documentation
Hi @me0608623! Please check out our latest Isaac Sim.
The lidar model output itself provides this information (not dependent on any vendor configuration – its depending on the auxOutputType):
  • Per point time information: GMO timestampNs + elements.timeOffsetNs
  • Per point channel id (“ring” for rotary sensors): channelId member of the auxData (set with auxOutputType = “EXTRA” or more; channels = [“EXTRA”] for kit >= 110.0)
Isaac Sim ROS2 message is also exposing this now.
