Hello
I tried below pipeline in Nano. But it throws error.
nano@nano:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1280, \
height=720, framerate=60/1, format=YUY2' ! videorate drop-only = true max-rate=30 ! \
nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! \
m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! \
nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_primary_nano.txt \
batch-size=1 unique-id=1 ! \
nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so ! n\
vinfer config-file-path= /opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt \
batch-size=16 unique-id=2 infer-on-gie-id=1 infer-on-class-ids=0 ! \
nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! \
nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink -v
Setting pipeline to PAUSED ...
Using winsys: x11
Creating LL OSD context new
0:00:01.201626700 14673 0x7f44003950 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<nvinfer1> NvDsInferContext[UID 2]:useEngineFile(): Failed to read from model engine file
0:00:01.201693993 14673 0x7f44003950 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<nvinfer1> NvDsInferContext[UID 2]:initialize(): Trying to create engine from model files
0:00:01.201863633 14673 0x7f44003950 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<nvinfer1> NvDsInferContext[UID 2]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
0:02:49.745193381 14673 0x7f44003950 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<nvinfer1> NvDsInferContext[UID 2]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_fp16.engine
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoRate:videorate0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstNvStreamMux:m.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvInfer:nvinfer0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvTracker:nvtracker0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvInfer:nvinfer1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvMultiStreamTiler:nvmultistreamtiler0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
/GstPipeline:pipeline0/GstNvDsOsd:nvdsosd0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
/GstPipeline:pipeline0/GstNvEglTransform:nvegltransform0.GstPad:src: caps = video/x-raw(memory:EGLImage), width=(int)1280, height=(int)720, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
/GstPipeline:pipeline0/GstEglGlesSink:eglglessink0.GstPad:sink: caps = video/x-raw(memory:EGLImage), width=(int)1280, height=(int)720, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
/GstPipeline:pipeline0/GstNvEglTransform:nvegltransform0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
/GstPipeline:pipeline0/GstNvDsOsd:nvdsosd0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvMultiStreamTiler:nvmultistreamtiler0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvInfer:nvinfer1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvTracker:nvtracker0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvInfer:nvinfer0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvStreamMux:m.GstNvStreamPad:sink_0: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoRate:videorate0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
ERROR: from element /GstPipeline:pipeline0/GstNvStreamMux:m: Input buffer number of surfaces (0) must be equal to mux->num_surfaces_per_frame (1)
Set nvstreammux property num-surfaces-per-frame appropriately
Additional debug info:
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream/gstnvstreammux.c(309): gst_nvstreammux_chain (): /GstPipeline:pipeline0/GstNvStreamMux:m
Execution ended after 0:00:00.399501937
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
