How to increase frame rate in deepstream python app, Jetson Nano
when i ran on the terminal: deepstream-app -c [config.txt], everything works fine and the video runs based on how fast the model infers eg. 30fps video would run at 40fps
i’m trying to replicate this setup in the deepstream_test1.py. i have added the videorate element in the pipeline, the video seems to play accordingly ie. when i set the rate 2x with videorate.set_property(‘rate’, 2), the video seems to run two times faster.
However, the callback probe ‘osd_sink_pad_buffer_probe’ seems to still run at a rate of 30fps. Is this cap set by the pgie element in the pipeline?
Appreciate your help, thanks!
• DeepStream Version
• TensorRT Version
• The pipeline being used
Where the position of the videorate is added ?
Is you add the videorate after osd ?
Can you share you code and configuration file ?
Hi, i was able to achieve what i want by setting the nveglglessink property ‘sync’ to 0
