• Hardware Platform (Jetson / GPU) GPU Tesla T4
• DeepStream Version DeepStream version 5.0
• JetPack Version (valid for Jetson only) N/A
I am running deepstream from docker: deepstream:5.0-dp-20.04-triton.
After successfully installed deepstream 5.0, I try to run the deepstream-app from sample_apps/deepstream-app with a stream from my local camera. I change one of the sample config files to receive source from rtsp and change output sink to a video file. However, the output is very lagging and choppy. Sometimes this would interfere with tracking and detection.
My question is how can I improve the quality of output stream/video? Is it something that I can config with the config file?
Command I run: $ ./deepstream-app -c config-file.txt
The config file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=4
num-sources=1
uri=rtsp://my-link
gpu-id=0
[streammux]
gpu-id=0
batch-size=1
live-source=1
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
[sink0]
enable = 0
type = 4
codec = 1
sync = 1
qos = 1
enc_type=0
source-id = 0
gpu-id = 0
bitrate = 1000000
rtsp-port = 8554
width = 640
height = 480
udp-port = 5400
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
[primary-gie]
enable=1
gpu-id=0
# Modify as necessary
model-engine-file=../../models/tlt_pretrained_models/peoplenet/resnet34_peoplenet_pruned.etlt_b1_gpu0_fp16.engine
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
config-file=config_infer_primary_peoplenet.txt
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=2
#1=h264 2=h265 3=mpeg4
codec=3
#encoder type 0=Hardware 1=Software
enc-type=0
sync=1
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=4
output-file=output.mkv
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[tracker]
enable=1
tracker-width=960
tracker-height=544
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
ll-config-file=../deepstream-app/tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
[tests]
file-loop=0
