I set 5 by 7 spheres on the fingertip as tactile contact points, the number of envs is 32, and I got this GPU memory error.
More details:
The application needs to increase PxgDynamicsMemoryConfig::foundLostAggregatePairsCapacity buffers to 1536, otherwise, the simulation will miss interactions, FILE /buildAgent/work/74336105e89c4a74/source/gpubroadphase/src/PxgAABBManager.cpp, LINE 1153
2023-11-01 15:26:39 [26,986ms] [Error] [omni.physx.plugin] PhysX error: The application needs to increase PxgDynamicsMemoryConfig::foundLostAggregatePairsCapacity to 5760 , otherwise, the simulation will miss interactions
, FILE /buildAgent/work/74336105e89c4a74/source/gpubroadphase/src/PxgAABBManager.cpp, LINE 1145
2023-11-01 15:26:39 [27,028ms] [Error] [omni.physx.plugin] PhysX error: Please select Physics Scene (create one if there is none), navigate to GPU section and increase “Gpu Found Lost Aggregate Pairs Capacity” value to at least 5248.
Anybody knows how to solve it? Thanks!
