How to initialize a video encoder on Jetson Thor?
We have successfully initialized the video encoder on Jetson orin using the following Topic patch:r35_31_add_nvvideoencoder.zip
However, the video encoder seems to have undergone some changes on the Thor, with the introduction of isGPUEnabled(), complicating its use.
Could you explain the benefits of including a GPU? And provide sample code for initializing the video encoder, similar to the one in r35_31_add_nvvideoencoder.zip:
static bool
encoder_initialize(context_t * ctx)
    ctx->enc = NvVideoEncoder::createVideoEncoder("enc0");
    if (ctx->enc == NULL)
        ERROR_RETURN("Failed to create video encoder");
    if (ctx->enc->setCapturePlaneFormat(V4L2_PIX_FMT_H264, ctx->cam_w,
                ctx->cam_h, 2 * 1024 * 1024) < 0)
        ERROR_RETURN("Failed to set up ENC capture plane format");
    if (ctx->enc->setOutputPlaneFormat(V4L2_PIX_FMT_YUV420M, ctx->cam_w,
                ctx->cam_h) < 0)
        ERROR_RETURN("Failed to set up ENC output plane format");
    if (ctx->enc->setBitrate(4<<20) < 0)
        ERROR_RETURN("Failed to set up ENC bitrate");
    if (ctx->enc->setProfile(V4L2_MPEG_VIDEO_H264_PROFILE_HIGH) < 0)
        ERROR_RETURN("Failed to set up ENC profile");
    if (ctx->enc->setLevel(V4L2_MPEG_VIDEO_H264_LEVEL_5_0) < 0)
        ERROR_RETURN("Failed to set up ENC level");
    if (ctx->enc->setRateControlMode(V4L2_MPEG_VIDEO_BITRATE_MODE_VBR) < 0)
        ERROR_RETURN("Failed to set up ENC rate control mode");
    if (ctx->enc->output_plane.reqbufs(V4L2_MEMORY_DMABUF, OUTPLANE_BUFNUM))
        ERROR_RETURN("Failed to set up ENC output plane");
    if (ctx->enc->capture_plane.setupPlane(V4L2_MEMORY_MMAP, 6, true, false) < 0)
        ERROR_RETURN("Failed to set up ENC capture plane");
    ctx->enc->subscribeEvent(V4L2_EVENT_EOS,0,0);
    return true;
This might show something.
/usr/src/jetson_multimedia_api/
/usr/src/jetson_sipl_api/sipl
We move to Video CODEC SDK on AGX Thor and isGPUEnabled() is true. Have you seen any error after applying the patch to Jetpack 7? It is supposed to work for basic encoding.
Our camera data format is YUV422 UYVY, which NVENC does not support. Therefore, we designed a method to use VIC to convert the format to YUV420 and then use NVENC for encoding.
After running the above process with offline UYVY data, the encoded H264 data frames display abnormally. I’m wondering if there’s a problem with the encoder configuration. Could you please help me identify possible causes?
The encoder configuration and calling logic are as follows:
for_nv_1020.zip (4.4 MB)
Thank you for your feedback.
We have updated the nvvideoencoder patch as shown in the attached file.
md5sum r38_2_add_nvvideoencoder.patch
5bb733564493db1f0bf1a97d5fa3a56d  r38_2_add_nvvideoencoder.patch
r38_2_add_nvvideoencoder.zip (3.6 KB)
After reviewing the zip file you provided, please try the patch below and confirm if it works correctly.
diff --git a/video_encoder.cc b/video_encoder.cc
--- a/video_encoder.cc
+++ b/video_encoder.cc
@@ -63,7 +63,7 @@ int VideoEncoder::initialize(EncodeContext &ctx) {
     if (m_videoEncoder->isGPUEnabled()) {
+        if (m_videoEncoder->setOutputPlaneFormat(V4L2_PIX_FMT_YUV420M, ctx.width_src,
-        if (m_videoEncoder->setOutputPlaneFormat(V4L2_PIX_FMT_NV12M, ctx.width_src,
                 ctx.height_src, V4L2_COLORSPACE_SMPTE170M, false) < 0) {
             syslog(LOG_ERR, "%s VideoEncoder setOutputPlaneFormat failed.\n", __func__);
             return -1;
Thank you for your review. It was indeed an issue with my setOutputPlaneFormat() method. After making these changes, my local code is now working correctly.
I’ll try r38_2_add_nvvideoencoder.zip
Hi DavidDDD:
My local code runs successfully, but the output h264 has an issue during playback:
As you can see, when a fast-moving object passes by, some ghosting appears in the image.
I also tested the r38_2_add_nvvideoencoder.zip patch you provided. After fixing the CUDA mapping issue (this is another fixed topic), it encoded and displayed correctly.
patch_and_h264output.zip (12.9 MB)
I saved the encoded result, and the same ghosting issue occurs during playback. Could you please take a look at this phenomenon and tell me what’s causing it?
Also, if I decode the h264, will this ghosting affect the decoding result?
Considering this ghosting issue might be a different issue, let’s use a new Topic track.
