I can install the 8800 as a primary card. When I install a cheaper card as the display card (5500), the system does not “see” the GTX
How do I install this correctly?
If you are using Windows is the 8800 listed under Display Adapters?
If you are using Linux is the card listed when you do a “/sbin/lspci”?
I have seen Opteron motherboards where you need to have 2 CPUs to enable both PCI-e slots. Which is the motherboard model?
Massimiliano
windows does not see it
Motherboard is Nvidia 680i SLI
Cheap GPU is in a slot closer to CPU so that it should be seen first …
Which brand and model?
It is a Winfast …
I am giving up and going back to one board
Please see this post: [url=“http://forums.nvidia.com/index.php?showtopic=29567&view=findpost&p=176025”]The Official NVIDIA Forums | NVIDIA
I’m running a FX 5200 as the primary video adapter (PCI), and 8800 GTS as the GPU (PCIe) under Windows XP.
[edit] Dell Precision 390
