How to install fskp_fuseburn_py
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Currently I am working on secure boot task and I am following the steps of the DRIVE documentation, currently I am trying to test the third step:
Do a test run of fuse burning with the -t option, which validates things but does not actually burn any fuses. Correct any errors. Only burn the fuses after a successful test run, and use the exact command line that worked with –t but change -t to -b . Example command for a test run:
./fskp_fuseburn.py -f <fuse_config> -i 63 -k fskp.test.key -c 0x23 --fskpcfg <fskp_cfg>  -B <board> -t
The problem is that my docker container doesn’t have the fskp_fuseburn.py on it. Neither the NVIDIA DRIVE Orin.
Q1) Where should the fskp_fuseburn.py should be ran?
Q2) How can i get/install the fskp_fuseburn.py? Here I see that this can be installed but I can’t find the fskp_fuseburn_py-.tgz file.
Dear @ricardo.gonzalez1,
This looks like a documentation issue. This file is part of PDK and not available in devzone release.
