Lantern would need to be ported to aarch64/arm64. Where would you normally download this from? If the aarch64/arm64 version does not exist then you’d need the source code to port it to a Jetson.
Related topics
| Jetson TX1 with L4T 23.1 - Doesn't support native aarch64 binaries? | 19 | 13390 | May 12, 2016 | |
| Installation of JetPack on Tegra TX1 | 2 | 1439 | October 18, 2021 | |
| Trouble installing JetPack onto Jetson TX1 | 4 | 1630 | October 18, 2021 | |
| Error: JetPack must be run on x86_64 HOST platform. Detected aarch64 platform. | 3 | 7858 | September 6, 2019 | |
| Install amd64 package lantern | 2 | 676 | October 18, 2021 | |
| fail to install cuda on tx1 | 4 | 1333 | October 18, 2021 | |
| Jetson TX1 64-bit Cross Compile | 3 | 1972 | July 14, 2016 | |
| Jetpack l4t-3.3 | 4 | 409 | October 18, 2021 | |
| Firefox installation after flashing sample file 23.2 | 2 | 1165 | June 24, 2016 | |
| Regarding JetPack installation problem: Error: JetPack must be run on x86_64 HOST platform. Detected | 7 | 6313 | December 20, 2018 |
