Hi ,
Please find the below error.
Building wheels for collected packages: numba, llvmlite
Building wheel for numba (setup.py) ... error
ERROR: Command errored out with exit status -4:
command: /usr/bin/python3.6 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-jmoy9iul/numba_40e2c0c5b0ce4caca90f4b04204e5642/setup.py'"'"'; __file__='"'"'/tmp/pip-install-jmoy9iul/numba_40e2c0c5b0ce4caca90f4b04204e5642/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-qtejdk_l
cwd: /tmp/pip-install-jmoy9iul/numba_40e2c0c5b0ce4caca90f4b04204e5642/
Complete output (0 lines):
ERROR: Failed building wheel for numba
Running setup.py clean for numba
command: /usr/bin/python3.6 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-jmoy9iul/numba_40e2c0c5b0ce4caca90f4b04204e5642/setup.py'"'"'; __file__='"'"'/tmp/pip-install-jmoy9iul/numba_40e2c0c5b0ce4caca90f4b04204e5642/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
ERROR: Failed cleaning build dir for numba
Building wheel for llvmlite (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3.6 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/setup.py'"'"'; __file__='"'"'/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-jw6t8foc
cwd: /tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/
Complete output (26 lines):
running bdist_wheel
/usr/bin/python3.6 /tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/ffi/build.py
LLVM version... Traceback (most recent call last):
File "/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/ffi/build.py", line 105, in main_posix
out = subprocess.check_output([llvm_config, '--version'])
File "/usr/lib/python3.6/subprocess.py", line 356, in check_output
**kwargs).stdout
File "/usr/lib/python3.6/subprocess.py", line 423, in run
with Popen(*popenargs, **kwargs) as process:
File "/usr/lib/python3.6/subprocess.py", line 729, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.6/subprocess.py", line 1364, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/llvm-9.0.1.src/llvm_build_dir/bin/llvm-config': '/tmp/llvm-9.0.1.src/llvm_build_dir/bin/llvm-config'
During handling of the above exception, another exception occurred:
File "/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/ffi/build.py", line 168, in <module>
main()
File "/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/ffi/build.py", line 158, in main
main_posix('linux', '.so')
File "/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/ffi/build.py", line 108, in main_posix
"to the path for llvm-config" % (llvm_config,))
RuntimeError: /tmp/llvm-9.0.1.src/llvm_build_dir/bin/llvm-config failed executing, please point LLVM_CONFIG to the path for llvm-config
error: command '/usr/bin/python3.6' failed with exit status 1
ERROR: Failed building wheel for llvmlite
Running setup.py clean for llvmlite
Failed to build numba llvmlite
Installing collected packages: llvmlite, numba
Attempting uninstall: llvmlite
Found existing installation: llvmlite 0.33.0
Uninstalling llvmlite-0.33.0:
Successfully uninstalled llvmlite-0.33.0
Running setup.py install for llvmlite ... error
command: /usr/bin/python3.6 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/setup.py'"'"'; __file__='"'"'/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-lu99_89u/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/rachel/.local/include/python3.6m/llvmlite
Complete output (29 lines):
running install
running build
got version from file /tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/llvmlite/_version.py {'version': '0.31.0', 'full': 'fe7d985f6421d87f613bd414479d29d912771562'}
running build_ext
**kwargs).stdout
main()
Rolling back uninstall of llvmlite
Moving to /home/rachel/.local/lib/python3.6/site-packages/llvmlite-0.33.0.dist-info/
from /home/rachel/.local/lib/python3.6/site-packages/~lvmlite-0.33.0.dist-info
Moving to /home/rachel/.local/lib/python3.6/site-packages/llvmlite/
ERROR: Command errored out with exit status 1: /usr/bin/python3.6 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/setup.py'"'"'; __file__='"'"'/tmp/pip-install-jmoy9iul/llvmlite_cfe2756d7dd74a668ac6c9cede993554/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-lu99_89u/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/rachel/.local/include/python3.6m/llvmlite Check the logs for full command output.
Please give me suggestions. I had installed the llvmlite-0.33.0.dist in Jetson nano . while installing the numba package it was uninstalling the llvmlite. But when I followed below blog steps for installing on jetson xavier , I didn’t get any errors.
