how to install Octave on Jetson Nano
I have tried to search octave subject here, but not found.
Can any one teach me how to install Octave on Jetson Nano?
Thanks !
You can search for all packages with “octave” in their description (and many won’t be what you want, but the ones starting with “octave” will be):
apt search octave | less
To install the basic application:
sudo apt-get install octave
This won’t necessarily use the GPU though. I couldn’t tell you what is required for this, but perhaps something like a GPU-aware BLAS library (I’m just speculating).
Hi linuxdev,
Thank you for your kindly help!
I’ll try your solution later.
I installed Octave on the Jetson Nano, but Octave is unable to plot graphs. There is something wrong with opengl_renderer. Below is the output from Octave when trying to make a plot. Will somebody from nvidia be able to look into this please?
warning: opengl_renderer: Error 1280 occurred in init_gl_context
warning: opengl_renderer: Error 1282 occurred drawing ‘patch’ object
I couldn’t tell you which library that might require, but there might be some conflict with using EGL instead of a full OpenGL. Someone else can probably point out what those missing gl contexts require.
