How to install onnx-tensorrt on Jetson devices?
Just as the topic, I want install onnx-tensorrt, the github link is below:
The building instruction is:
cd onnx-tensorrt
mkdir build && cd build
cmake .. -DTENSORRT_ROOT=<path_to_trt> && make -j
// Ensure that you update your LD_LIBRARY_PATH to pick up the location of the newly built library:
export LD_LIBRARY_PATH=$PWD:$LD_LIBRARY_PATH
I set the <path_to_trt> to usr/src/tensorrt
And I got the Error: third_party/onnx does not contain a CmakeLists.txt file.
Could you show me how to install it?
Thanks A LOT!!
Please check this comment for the detail instructions:
Hi, thanks a lot for reply
while, I can’t read the commands clearly, could you show them line by line?
Thanks a lot!!
@xushoushuai Have you resolved your problem? I am also facing some problem while building onnx-tensorrt in Xavier NX.
