Almost the same sequence of commands from “air1kdf” above. just the first command I used was different: sudo fallocate -l 4.0G /swapfile # this is the difference
sudo chmod 600 /swapfile sudo mkswap /swapfile
sudo swapon /swapfile
Also, to make the swapfile activated during reboot, edit /etc/fstab:
$ sudo nano /etc/fstab
And add the following line:
/swapfile none swap 0 0
Save it and it should activate the swapfile after your next reboot.
Although marked as “solved”, it really isn’t.
OpenCV4.1 IS available loaded with Jetpack 4.3. out of the box, but it does not appear as the “opencv-python” module, so it is not recognized as available by other packages such as stable-baselines. If you do a apt-install opencv you get version 3.2 and it appears as the module " python3-opencv" which is also not recognized by loading packages as OpenCV.
How can we get the pre-loaded OpenCV4.1 to appear as the requested module “opencv-python”?
That’ll save you a few hours of waiting for the script to build and is probably eaiser to test, deploy, and far more repeatable than the script itself. Make sure to use the --runtime nvidia flag to access the GPU or it’ll segfault when you try to “import cv2” or equivalent. Just:
sudo docker run --user $(id -u):$(cut -d: -f3 < <(getent group video)) --runtime nvidia -it --rm mdegans/tegra-opencv:latest
The --user bit is optional but recommended to avoid running the container as root.
And you can then:
$ sudo docker run --user $(id -u):$(cut -d: -f3 < <(getent group video)) --runtime nvidia -it --rm mdegans/tegra-opencv:latest
[sudo] password for your_username_here:
Unable to find image 'mdegans/tegra-opencv:latest' locally
latest: Pulling from mdegans/tegra-opencv
3b5e2c02f523: Already exists
b9448035bb0a: Already exists
ec9ea6732d09: Already exists
515b0d7ffbf7: Already exists
7663c88dd173: Already exists
5dd4bd16e931: Already exists
5231bd433c70: Already exists
9e017cdad796: Already exists
0c8ba4b0f40b: Already exists
de2653fc4eda: Already exists
21b3dc12ac76: Already exists
18d3041d2711: Already exists
8b4bed079038: Already exists
efb313fc2a73: Already exists
5c1e867b3d6d: Already exists
aee12882d462: Pull complete
c8c16c286602: Pull complete
eacb1135637c: Pull complete
92fdb5579a06: Pull complete
4d54fa5df78f: Pull complete
46d431fc04e0: Pull complete
Digest: sha256:379826dbe07d5135615e02de0efc62da59ddb6097ca98e639f971db907b96776
Status: Downloaded newer image for mdegans/tegra-opencv:latest
I have no name!@e71c4e768a02:/usr/local/src/build_opencv$ python3
Python 3.6.9 (default, Apr 18 2020, 01:56:04)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> cv2.cuda.printCudaDeviceInfo(0)
*** CUDA Device Query (Runtime API) version (CUDART static linking) ***
Device count: 1
Device 0: "Xavier"
CUDA Driver Version / Runtime Version 10.20 / 10.20
CUDA Capability Major/Minor version number: 7.2
Total amount of global memory: 15823 MBytes (16591372288 bytes)
GPU Clock Speed: 1.38 GHz
Max Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072,65536), 3D=(16384,16384,16384)
Max Layered Texture Size (dim) x layers 1D=(32768) x 2048, 2D=(32768,32768) x 2048
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 2147483647 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support enabled: No
Device is using TCC driver mode: No
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 0 / 0
Compute Mode:
Default (multiple host threads can use ::cudaSetDevice() with device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.20, CUDA Runtime Version = 10.20, NumDevs = 1
If you’re still on jetpack 4.3, you can use jp-r32.3.1-cv-4.3.0 instead of latest as a tag.
