Some context:
cat /etc/nv_tegra_release
prints out:
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
I tried to build pytorch from source on a conda environment running python 3.10 as follows:
export USE_NCCL=0 ; \
export USE_DISTRIBUTED=1 ;
export USE_QNNPACK=0 ;
export USE_PYTORCH_QNNPACK=0 ;
export TORCH_CUDA_ARCH_LIST=“8.7” ;
export PYTORCH_BUILD_VERSION=2.0.1 ;
export PYTORCH_BUILD_NUMBER=42
python setup.py bdist_wheel
But i get this error message:
[642/6109] Building C object confu-deps/XNNPACK/CMakeFiles…prod.dir/src/pf32-gemm/pf32-gemm-32x32-minmax-neonsme2.c.o
FAILED: confu-deps/XNNPACK/CMakeFiles/microkernels-prod.dir/src/pf32-gemm/pf32-gemm-32x32-minmax-neonsme2.c.o
/usr/bin/cc -DFXDIV_USE_INLINE_ASSEMBLY=0 -DXNN_ENABLE_ARM_BF16=0 -DXNN_ENABLE_ARM_DOTPROD=1 -DXNN_ENABLE_ARM_FP16_SCALAR=1 -DXNN_ENABLE_ARM_FP16_VECTOR=1 -DXNN_ENABLE_ARM_I8MM=0 -DXNN_ENABLE_ARM_SME2=1 -DXNN_ENABLE_ARM_SME=1 -DXNN_ENABLE_ASSEMBLY=1 -DXNN_ENABLE_AVX256SKX=0 -DXNN_ENABLE_AVX256VNNI=0 -DXNN_ENABLE_AVX256VNNIGFNI=0 -DXNN_ENABLE_AVX512AMX=0 -DXNN_ENABLE_AVX512F=1 -DXNN_ENABLE_AVX512FP16=0 -DXNN_ENABLE_AVX512SKX=1 -DXNN_ENABLE_AVX512VBMI=1 -DXNN_ENABLE_AVX512VNNI=1 -DXNN_ENABLE_AVX512VNNIGFNI=1 -DXNN_ENABLE_AVXVNNI=0 -DXNN_ENABLE_AVXVNNIINT8=0 -DXNN_ENABLE_CPUINFO=1 -DXNN_ENABLE_DWCONV_MULTIPASS=0 -DXNN_ENABLE_GEMM_M_SPECIALIZATION=1 -DXNN_ENABLE_HVX=1 -DXNN_ENABLE_KLEIDIAI=0 -DXNN_ENABLE_MEMOPT=1 -DXNN_ENABLE_RISCV_VECTOR=1 -DXNN_ENABLE_SPARSE=1 -DXNN_ENABLE_VSX=1 -I/home/nvidia/code/pytorch/third_party/XNNPACK/include -I/home/nvidia/code/pytorch/third_party/XNNPACK/src -I/home/nvidia/code/pytorch/third_party/pthreadpool/include -I/home/nvidia/code/pytorch/third_party/FXdiv/include -isystem /home/nvidia/code/pytorch/third_party/protobuf/src -O3 -DNDEBUG -std=c99 -fPIC -Wno-psabi -O2 -pthread -fno-math-errno -march=armv8.2-a+sve+sve2 -MD -MT confu-deps/XNNPACK/CMakeFiles/microkernels-prod.dir/src/pf32-gemm/pf32-gemm-32x32-minmax-neonsme2.c.o -MF confu-deps/XNNPACK/CMakeFiles/microkernels-prod.dir/src/pf32-gemm/pf32-gemm-32x32-minmax-neonsme2.c.o.d -o confu-deps/XNNPACK/CMakeFiles/microkernels-prod.dir/src/pf32-gemm/pf32-gemm-32x32-minmax-neonsme2.c.o -c /home/nvidia/code/pytorch/third_party/XNNPACK/src/pf32-gemm/pf32-gemm-32x32-minmax-neonsme2.c
cc1: error: invalid feature modifier ‘sve2’ in ‘-march=armv8.2-a+sve+sve2’
cc1: note: valid arguments are: fp simd crypto crc lse fp16 rcpc rdma dotprod aes sha2 sha3 sm4 fp16fml sve profile rng memtag sb ssbs predres; did you mean ‘sve’?
[651/6109] Building C object confu-deps/XNNPACK/CMakeFiles…/qd8-f16-qb4w-gemm-1x16-minmax-neonfp16arith-mlal-lane.c.o
ninja: build stopped: subcommand failed.
