When I try to install ros kinetic on Drive Software 9.0 with DriveOS 5.1.0.2. I got errors after the reboot. Camera samples won’t, record-qtgui won’t see cameras neither delete files from SSD harddisk. So I want to learn if there is a proper install guide for ROS.
kind of works, we can start camera streams again. However, recorder-tool still does not work. After uninstalling ROS, everything works perfectly again.
Does anybody have any suggestions for a better workaround?
