How to install scikit-image through archiconda on Jetson TX2 JecPack 4.4version?
I saw previous topic.It installs dependencies into my system python3 envrioment instead of achiconda’s virtual enviroment through using “sudo pip3 install…”.
However I use archiconda to create my virtual environment.So how to install scikit-image in archiconda virtual environment?
Hi zhou11,
I don’t have answer for this issue, may other developers help to share experiences if the done something similar.
Thanks !
I already have solved this problem.
Below is my solution
Follwing previous topic,I install all dependencies and use sudo pip3 to install scikit-image in my system python3.6.
Then I successfully installed the skit into Archiconda’s virtual environment through
pip install scikit-image.
