How to install the latest gpiod
I know this may not be directly related to the NV platform, but I’m looking for some guidance. I want to control GPIO from user space and have been following the instructions to install gpiod from this link: GPIO Support — NVIDIA IGX Orin - User Guide. However, I’m unable to control the GPIO levels using the gpioset command.
I’ve come across a discussion indicating that updating to the latest version of gpiod can resolve this issue: Cannot Control GPIOs for JP61 - #16 by JerryChang. It mentions installing the latest gpiod can solve my problem. So, I attempted to follow the instructions listed in this discussion: NVIDIA Jetson Linux 36.4 (JetPack 6.1) GPIO控制方法变更-机载电脑-Amovlab阿木实验室-让机器人研发更高效! -.
I didn’t encounter any error messages during installation, and I ensured that the line export LD_LIBRARY_PATH=/home/nvidia/Downloads/libgpiod/lib/.libs:$LD_LIBRARY_PATH is present in the .bashrc file. However, when I run the command gpioinfo --version, I receive the error: /usr/bin/gpioinfo: No such file or directory.
My question is: how can I successfully install the latest version of gpiod?
Thanks in advance.
Hi chiaueng,
Which GPIO would you like to control?
Have you configured the pinmux before using it as GPIO/Output?
Please share the detailed steps about the steps/commands to configure/control GPIO.
Hi @KevinFFF ,
[Plaform] Jetson AGX Orin Developer Kit 64G + an adapter board to connect single imx219 camera
[SDK and source code pkg] JetPack 6.1 Jetson Linux Version 36.4
[adpater board]
I was trying to control GPIO 13, from Orin_Jetson_Series_Pinmux_Config_Template_2.0.xlsm, i can see it’s GPIO3 PAC.02
  1. Since it’s already default as gpio pin, so i don’t modify its pinmux attribute.
  2. from gpioinfo, i can see PAC.02 is gpiochip0 line 140.
  3. then i input the gpio command as below, but cannot change its value.
    Screenshot from 2025-03-10 13-50-03
I tried to use v2.1.3. Then I see it can work with the following steps :
  1. gpioset -c 0 140=1
  2. ctrl+c
  3. gpioget -a --numeric -c /dev/gpiochip0 140 -->the value becomes 1
but it’s strange that i need to do the step2 (ctrl+c), i also add -z option but still still not work for my use case.
Is there a way to leave the command after setting it ?
I treid to use the parameter of “–hold-period”, it seems it can work now.
Please do not run gpioget command, which may configure the pin as Input.
You can also specify --mode=wait to keep its state.
Or you can refer to Jetson/L4T/peripheral/ - eLinux.org to know how we verify GPIO controlling.
