Recently, I try to run my program on orin, but there is ModuleNotError "No modele named ‘torch_sparse’ ".
Firstly, I type “pip install torch_sparse” in the terminal, but there is an error which tells “subprocess-exited-with-error && python setup.py bdist_wheel did not run successfully.” At the end of printed message, it says “failed building wheel for torch_sparse”.
Secondly, I attempt to search solutions in the web. However, I can only find the wheel for windows, that is “…win_amd64.whl” or for Linux_x86, that is “linux_x86_64.whl”. It does not function. When I type “pip install torch_sparse-0.6.14-cp310-cp310-linux_x86_64.whl”,there is an error"…is not a supported wheel on the platform".
Thanks for your reply. I have installed pytorch and torchvision in the orin,just follow the website you give, but later torch_sparse package is not able to be installed any more.
I didn’t find the right version of .whl files from Internet. There is no available version for aarch64, like the following page: https://pytorch-geometric.com/whl/. Luckily, I successfully install it using the pip conmand, which didn’t function before today, and now I don’t know how to explain this.
