How to interprete urdf file to deformable object
How to interprete urdf file to deformable object in Isaac Lab
I’m trying to use my own urdf file to create a deformable object in Isaac Lab.
My URDF file is defined as:
<?xml version="1.0" encoding="utf-8"?>
    <robot name="box_0">
        <link name="box_0">
            <fem>
                <origin rpy="0.0 0.0 0.0" xyz="0 0 0" />
                <density value="100" />
                <youngs value="1005"/>
                <poissons value="0.3"/>
                <damping value="0.0" />
                <attachDistance value="0.0"/>
                <tetmesh filename="../../meshes/multi_box_1kPa/box_0.tet"/>
                <scale value="1.0"/>
            </fem>
        </link>
    </robot>
I used convert_urdf.py --make-instanceable to convert the urdf file to USD file.
I also tried convert_mesh.py --make-instanceable --collision-approximation convexDecomposition --mass 1.0.
Then I initialize the deformable object by
deformable = DeformableObjectCfg(
        prim_path="{ENV_REGEX_NS}/Deformable",
        spawn=sim_utils.UsdFileCfg(
            usd_path=box_usd,
        init_state=DeformableObjectCfg.InitialStateCfg(pos=(0.0, 0.5, 1.0)),
The tutorial and demo provided in the documentation are all use MeshCfgto generate deformable object, which can specify the deformable parameters inside
deformable_props=sim_utils.DeformableBodyPropertiesCfg(rest_offset=0.0, contact_offset=0.0),
visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.5, 0.1, 0.0)),
physics_material=sim_utils.DeformableBodyMaterialCfg(density=100, poissons_ratio=0.3, youngs_modulus=1005),
Thus I can not successfully create the deformable object
RuntimeError: Failed to find a deformable body when resolving '/World/envs/env_.*/Deformable'. Please ensure that the prim has 'PhysxSchema.PhysxDeformableBodyAPI' applied.
So what is the correct way to generate deformable objects using urdf/mesh file? Is my urdf file wrong?
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
