I’m playing with tiny text generation model on my Jetson Nano (JetPack 4.6 [L4T 32.6.1] ), and sometimes I get this exception
2022-07-24 05:03:49.700418: I tensorflow/core/common_runtime/bfc_allocator.cc:1058] Sum Total of in-use chunks: 155.25MiB
2022-07-24 05:03:49.700449: I tensorflow/core/common_runtime/bfc_allocator.cc:1060] total_region_allocated_bytes_: 162787328 memory_limit_: 162787328 available bytes: 0 curr_region_allocation_bytes_: 325574656
2022-07-24 05:03:49.700489: I tensorflow/core/common_runtime/bfc_allocator.cc:1066] Stats:
Limit: 162787328
InUse: 162787328
MaxInUse: 162787328
NumAllocs: 7492
MaxAllocSize: 22020096
Reserved: 0
PeakReserved: 0
LargestFreeBlock: 0
2022-07-24 05:03:49.700980: W tensorflow/core/common_runtime/bfc_allocator.cc:467] ************************xxxx************************************************************************
2022-07-24 05:03:49.701082: W tensorflow/core/framework/op_kernel.cc:1767] OP_REQUIRES failed at split_op.cc:308 : Resource exhausted: OOM when allocating tensor with shape[32,256] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
As far as I understand, there was not enough memory, but the following is unclear
- What kind of memory, GPU or RAM?
- What took all the memory, data or model layers?
- Is it possible to evaluate the amount of needed memory before the fitting operation? How?
May be there is a step-by-step guide about memory allocation and memory amount evaluation for Nvidia chips?
Thank you!
