In my project there are multiple classes that I need to track but at the same time there are classes which shouldn’t be tracked because otherwise the tracker would discard some detections that are needed per frame.
Is there a way I could flag to not track certain classes and just pass the raw data instead?
nvtracker don’t support bypass objects based on class. What is the mean of above? Do you mean the number of the object lager than maxTargetsPerStream: Gst-nvtracker — DeepStream documentation?
no, I meant that if the tracker decides that an object is not part of a track, the object will be discarded and only appears if being tracked.
There is shadow tracking in nvtracker: Gst-nvtracker — DeepStream documentation if the tracking confidence is low. If so, you can tune nvtracker config parameter(refer: Troubleshooting — DeepStream documentation) to avoid it instead of bypass nvtracker based on class.
I’ve seen this but this would apply equally to all classes, right? I don’t want to degrade the tracking quality of other classes if I enable results from shadow tracking but maybe I can just pick certain classes from there?
Yes, the config parameters will apply to all classes. Why you want different config parameters for different class? Can you share some videos to show the issue?
Sorry, I’m not able to share the video since I don’t have the rights for it.
The reason I want different parameters is the exact same as stated initially. I have classes that I need to track, the parameters are tuned to those classes. Other classes I don’t need to track. Now if I tune the tracking parameters to those classes that I don’t need to track, obviously this will impact the classes that I need to track.
I have found a solution already, what I do now is to remove the objects that I don’t need for tracking before the tracking module and then after tracking I add them back in.
Is it possible for you to add a new feature to tracking? One where you can exclude certain classes from being tracked and just pass their raw detections downstream? I can imagine that this wouldn’t be too hard to add, since you already have a way to ignore ALL classes.
Glad to know you have a solution for the issue.
Thanks for you suggestion. Seems nvtracker need handle different class separately.
