How to kill pipeline gracefully
**• Hardware Platform GPU
• DeepStream Version --------> 7.0
• TensorRT Version -------> 8.6.1
**• NVIDIA GPU Driver Version -----> 555
I want to kill the pipeline gracefully
def stop_pipeline(self):
print(“Stopping pipeline…”)
if self.pipeline:
self.pipeline.send_event(Gst.Event.new_eos())
self.pipeline.set_state(Gst.State.NULL)
if self.loop:
self.loop.quit()
print(“Pipeline stopped gracefully”)
This problem has nothing to do with deepstream, just add signal processing to the python program
import sys
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
import signal
is_running = True
def sigint_handler(signum, frame):
    global is_running
    print("\nReceived interrupt signal. Shutting down gracefully...")
    is_running = False
    main_loop.quit()
def bus_call(bus, message, loop):
    t = message.type
    if t == Gst.MessageType.EOS:
        print("End of stream")
        loop.quit()
    elif t == Gst.MessageType.ERROR:
        err, debug = message.parse_error()
        print(f"Error: {err}")
        print(f"Debug info: {debug}")
        loop.quit()
    return True
def main():
    global main_loop
    # Initialize GStreamer
    Gst.init(None)
    # Create the main loop
    main_loop = GLib.MainLoop()
    # Create a simple DeepStream pipeline
    pipeline = Gst.Pipeline.new("deepstream-signal-example")
    # Create pipeline elements (example with videotestsrc)
    source = Gst.ElementFactory.make("videotestsrc", "test-source")
    converter = Gst.ElementFactory.make("nvvideoconvert", "converter")
    sink = Gst.ElementFactory.make("autovideosink", "video-output")
    if not pipeline or not source or not converter or not sink:
        print("Not all elements could be created.")
        return
    # Add elements to the pipeline
    pipeline.add(source)
    pipeline.add(converter)
    pipeline.add(sink)
    # Link the elements
    source.link(converter)
    converter.link(sink)
    # Get the bus and add a watch
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, main_loop)
    # Start the pipeline
    pipeline.set_state(Gst.State.PLAYING)
    print("Pipeline started. Press Ctrl+C to exit.")
    # Set up signal handling
    signal.signal(signal.SIGINT, sigint_handler)
    # Run the main loop
    try:
        main_loop.run()
    except Exception as e:
        print(f"An error occurred: {e}")
    finally:
        # Clean up
        print("Pipeline stopped.")
if __name__ == "__main__":
    main()
