How to know if it is Pegasus or Xavier
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.1.7402
other
Host Machine Version
native Ubuntu 18.04
other
Just start to work on the Drive System and get a basic question…
How do I know if the drive system is Pegasus or Xavier?
we ordered the Pegasus, but everything we received is packaged in Xavier packaging, even the HW quick start guide is for Xavier. How can I determine this is Pegasus system not Xavier physically? (different number of connectors?, etc…) and How do I know if it is Pegasus once I power on the system? (running some applications?)
Thank you!
Hi @JustinCNHi ,
Please run “lspci” on Xavier A&B and share us the results. You should be able to see “3D controller: NVIDIA Corporation Device” listed out. Thanks.
Hi @VickNV ,
Thank you for quick response.
it shows “3D controller: NVIDIA Corporation Device leba (rev al)” on both Xavier A&B, as shown above. I assume this means the system has 2 Turing GPUs, so it is the Pegasus, correct?
I also found a label on the housing with “940-63550-2200-100 AR”, I believe this is the Pegasus part number as this number is mentioned in some other post. Please confirm? Thank you.
It looks your devkit does have two “Turing” Discrete GPUs so it should be pegasus.
For Product Number, let me check and get back to you.
@VickNV ,
thank you for confirming it is the Pegasus. Do you get any feedback on the Part Number?
According to below from https://developer.nvidia.com/drive/drive-agx, your ““940-63550-2200-100 AR”” should be Pegasus.
