Current supported librealsense version 2.29 doesn’t work with d435i with USB 3.x.
The error is “Cannot detect any devices.”
But I manage to make it work with version 2.31 in python but not isaac. I want to know is there any easy way to link the pre-compiled library, i.e. link librealsense.so.2.31.
Here is the steps for me to make the python code work in xaiver:
git clone https://github.com/jetsonhacksnano/installLibrealsense
cd installLibrealsense
./installLibrealsense.sh
./buildLibrealsense.sh
Python code:
import pyrealsense2 as rs
import usb
import numpy as np
import cv2
import time
ID_VENDOR_REALSENSE = 0x8086 # Intel
MANUFACTURER_REALSENSE = "Intel(R) RealSense(TM)"
PRODUCT_REALSENSE = "Intel(R) RealSense(TM)"
CAPTURE_WIDTH = 640
CAPTURE_HEIGHT = 480
CAPTURE_FPS = 60
def reset_realsense_devices():
usb_devices = usb.core.find(find_all=True)
def is_realsense_device(dev):
is_same_idVendor = dev.idVendor == ID_VENDOR_REALSENSE
if not is_same_idVendor:
return False
is_same_manufacturer = MANUFACTURER_REALSENSE in dev.manufacturer
is_same_product = PRODUCT_REALSENSE in dev.product
return is_same_manufacturer and is_same_product
realsense_devices = filter(is_realsense_device, usb_devices)
for dev in realsense_devices:
dev.reset()
def get_realsense_serialnumbers(max_n=1):
# pyrealsense2.context
ctx = rs.context()
# pyrealsense2.device_list
devices = ctx.query_devices()
serial_numbers = map(lambda device: device.get_info(rs.camera_info.serial_number), devices)
serial_numbers_ = list(serial_numbers)[:max_n]
return serial_numbers_
def setup_realsense_camera(device_serial_number, width, height, fps):
# ストリーム(Color/Depth)の設定
config = rs.config()
config.enable_device(device_serial_number)
config.enable_stream(rs.stream.color, width, height, rs.format.bgr8, fps)
config.enable_stream(rs.stream.depth, width, height, rs.format.z16, fps)
# ストリーミング開始
pipeline = rs.pipeline()
profile = pipeline.start(config)
return pipeline, profile
def get_images(pipeline):
frames = pipeline.wait_for_frames()
# RGB
RGB_frame = frames.get_color_frame()
RGB_image = np.asanyarray(RGB_frame.get_data())
# depth
depth_frame = frames.get_depth_frame()
depth_image = np.asanyarray(depth_frame.get_data())
return RGB_image, depth_image
def main():
# reset usb connection of realsense devices
# setup pipeline
serial_numbers = get_realsense_serialnumbers(max_n=1)
if len(serial_numbers) == 0:
print("Not found realsense devices")
return
pipeline, _ = setup_realsense_camera(serial_numbers[0], CAPTURE_WIDTH, CAPTURE_HEIGHT, CAPTURE_FPS)
# get image and show
i = 0
while True:
print(i)
RGB_image, depth_image = get_images(pipeline)
# depth_colormap = cv2.applyColorMap(cv2.convertScaleAbs(depth_image, alpha=0.08), cv2.COLORMAP_JET)
cv2.imshow("realsense image", RGB_image)
key = cv2.waitKey(1)
if key == 27: # ESC
break
i += 1
if __name__ == "__main__":
main()
